So the last two oil changes have been Shell Rotella T as opposed to ATF type f. Probably not related but anyway. The last two changes have been a little milky. I assume this means I have a leaky water pump shaft seal? I have not lost enough water to be able to tell.
Is that seal in the outer case? Figured I would change when installing revloc and clutch actuator seal.
I have a manual...
oil is a little milky
- frankenschwinn
