Bad clatter coming from countershaft
There is an awful clatter coming from my kdx. It's a 2004. I traced the noise, using a screwdriver as a stethoscope, to the countershaft. It is loudest with the screwdriver tip right on the shaft. It sounds kinda like a gear not meshing or something. Shifting gears makes no differences, and it seems that speed doesn't either, though I didn't go faster than walking speed with that noise. The last thing I did before it started was slide the bike sideways into a tree, and the left side hit pretty hard. Wonder what that could have done? I don't really want to split cases, so I'm hoping I won't have to. I plan on pulling the clutch/ignition covers to see if I can see anything, but I'm wondering if anyone might know what this noise is.
At this point, it could be just abot anything - kick start mechanism, clutch, or transmission. The best approach is to remove the clutch cover (with the engine still in the frame) and take a look. To go any further means splitting the cases, which means that the engine has to come out of the frame.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
- scheckaet
remove clutch cover, do not forget to support the kips actuator shaft and also that the nut holding onto the claw is reverse.
Is your kips valve really working? Could be that the actuator is broken and that you have some of that stuck in the clutch, gear mechanism, kickstarter gear...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
