dyna ring ?? springs oil weight
grumpyman
Post by grumpyman »
first ride on the dyna ringed beast 2day ... interesting
it did stall on me a couple times though
and i spent some time tweaking it on the trail feeling it out wanting a little less rubber band effect
SOME QUESTIONS
what oil are you running belray 75 or syntec 5/50 or something else??
how many springs?? mine got sent with 3 anyone running something else??
i would love to keep using type f if possible
any random tips on dyna ring use/setup ?
anything you've learned the hard way??
found this decent writeup on the revloc blog
http://www.dirtybikesxtreme.ca/index.ph ... &Itemid=91
grumpyman
Post by grumpyman »
talked alan at revloc about the dyna ring
he's running dextron micron 3 atf fluid in his kdx with no ill effects. so thats a cheaper option than the 5/50 syn or the hard to find belray 75 (i could only find the 80wt which was $10 a quart)
i'm gonna drain the 80wt and re install then ride it while changing cable tension then maybe try two springs as he thought that'd give me a more solid hookup off idle without having to rev so hard to get it to engage
hey mods any chance of a dyna setup and use sticky
