Front Brake Problems (long, sorry)
Posted: 09:00 am Aug 09 2010
It’s been one thing after another since I brought my KDX home. I knew it was a project when I bought it, but when I test rode it, the front brakes worked fine. Now, not so much.
I have been putting fork seals and bearings in the front end and am trying to get it all back together. Part of that was new brake pads, since the old ones were oil soaked due to the bad fork seals. I had a hard time getting the pistons pushed back in (with the bleeder open), but got them pushed in just far enough so the rotor would fit between the new pads. Then I figured I would replace the brake fluid using a Mity-Vac, just like I have done many time in the past on other bikes.
I cracked the bleeder, took the master cylinder cover off, and drew a vacuum. The vacuum held and it would not draw any fluid through the system. The lever was limp and it would not compress the brake pads.
I had the bleeder loose enough I was surprised the vacuum didn’t leak down through the threads. I removed the bleeder screw and hand pumped the brake, covering the bleed hole when the lever was returning. It sucked a little fluid out of the reservoir but it wasn’t moving nearly as much fluid as I would have expected.
I cleaned the bleeder screw and took the brake line off at the master cylinder and put that end of the brake line in a jar of brake fluid. Using the Mity-Vac, I was able to pull fluid through the line and caliper without an issue. Both banjo screws are passing fluid fine.
So I thought the problem was narrowed to the master cylinder. I took it apart expecting to see an issue but did not. The bore looks fine. There is no corrosion, and the cup seals seemed to seal well against the bore when I slipped the spool back in. I blew air through the bore to clear any potential clogging of the relief and supply ports in the master cylinder. The odd thing is, the manual shows two separate ports, but I can only see one in my master cylinder. Since the brakes worked earlier and apparently worked fine for the previous owner, I’m assuming this is not an issue.
So I don’t know what else the problem could be. The caliper is getting rebuilt since I am this far into it. I blew the pistons out of the caliper with compressed air. They were tight and when they exited their bores they made a heck of a loud pop. I don’t know if that is typical or not.
I am convinced the problem is with the master cylinder, but I don’t know what the issue might be with it. The bleeding process described in the service manual talks about stroking the lever till there are no air bubbles seen in the fluid reservoir, which I have done. Is there any other way to bleed the master cylinder that I am missing? It seems like there is air in the system.
With the cylinder assembled, full of fluid, bled (as far as I know), but off the bike and not hooked to the brake line, when you squeeze the lever nothing comes out of the brake line port. I’d expect it to shoot fluid out. There is no resistance to the lever pull except the return spring (when its all hooked up).
Anyone have any ideas? I’m certainly no expert at this so I could be missing something pretty obvious. Thanks in advance.
turtle
turtle
