Fuel mixing - who's right?
turtle
Post by turtle »
Yes, I am still a newbie. Our four wheelers are 2 stroke but they are injected, so ...
I saw somewhere on line (this site, maybe) that you should mix fuel according to the oil maker's recommendations and not what Kaw says. I bought some Amsoil 2-stroke oil and it says 50:1 :shock:. Seems a little lean to me.
What is the correct approach with mixing up your fuel? The Gas Oil Mixture Ratio Calculator on this site is pretty cool, BTW.
Thanks.
turtle
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Actually... that would make it rich. I run 50:1 Amsoil... no problems.
turtle
Post by turtle »
OK, now I am definitely confused, Inda. It probably is because of how I used the term "lean". I meant lean on oil. I thought 50:1 meant 50 parts fuel to 1 part oil, so 50:1 would be a leaner *oil* mixture than 32:1 (or richer on fuel). Looking at your Gas Oil Mixture Ratio Calculator, if I use 5 gallons fuel, I need 20 oz oil for 32:1. For 50:1, I need 12.8 oz per your calculator. So I think this supports my understanding. So, am I right or off by a country mile?
Anyway, bottom line is my concern is that 50:1 would be too little amount of oil when Kaw calls for 32:1 or 40:1. Your suggestion is to go ahead and mix it at 50:1 as I understand it.
Thanks for educating me.
Bill
Central IL
2004 KDX220R
johnyblaze
Post by johnyblaze »
I don't like the idea of going 50:1 just due to the possible outcome if it's not OK. Hey, I feel pretty comfy at 40:1 and don't feel like I'm wasting oil being too careful.
More importantly, my bike's jetted at 40:1 so I'm keeping it.
1998 KDX220 with goodies
2002 KTM LC4E
2001 Suzuki Bandit 1200S
bcdonyo
Post by bcdonyo »
johnyblaze wrote:I don't like the idea of going 50:1 just due to the possible outcome if it's not OK. Hey, I feel pretty comfy at 40:1 and don't feel like I'm wasting oil being too careful.
+1, I've run 40:1 in my smokers for years with no problems. May have gotten the same results with 50:1, but it would make me nervous. :rolleyes:
You can run just about whatever mix you want as long as you jet for it. If you don't feel like jetting the bike, then run what Kawi suggests. 32:1 I think.
What Inda meant was that adding more oil does not make a richer mix. Lean / rich refers to air / fuel mixture, not oil content. More oil = less fuel, so the air to fuel ratio becomes leaner. Make sense?
ihatefalling
Post by ihatefalling »
Indawoods wrote:Actually... that would make it rich. I run 50:1 Amsoil... no problems.
+ 1
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
turtle
Post by turtle »
juliend wrote:You can run just about whatever mix you want as long as you jet for it. If you don't feel like jetting the bike, then run what Kawi suggests. 32:1 I think.
It sure does. Thanks.
Bill
Central IL
2004 KDX220R
ogri
Post by ogri »
have yet to meet a two-stroke owner this side of the pond who mixes anything other than 50:1
fully synthetic of course.
40:1 for me. Works good and makes me feel all warm and fuzzy inside.
David_L6
Post by David_L6 »
We run Klotz and AV gas at 32:1.
I'm of the "oil is cheaper than parts" line of thinking.... I guess that comes from 30 years of racing outboard hydros where some of us take motors that were designed to turn 5500 RPMs at full throttle and wind them up to 8500+ RPMs.
The extra oil makes those bearings smile and doesn't hurt the ring sealing a bit either. :shh:
Tedh98
Post by Tedh98 »
I was starting to think I was the only one here running 32:1. I do it mostly out of convenience though. My kids need to run 32:1 in their engines and I don't want to deal with having 2 gas cans or mixing things up and putting 40:1+ in their engines by mistake.
Mr. Wibbens
Post by Mr. Wibbens »
50:1 here, my bike feels a lot more Zippy
Run the same in all my power equipment
So, I was just about to mix up some fresh gas and for the first time read the bottle. I use golden spectro oil, the bottle said to mix one 12 oz. bottle with five gallons of gas to get 53/1. The bottle claims that it is "special" oil that can part the seas and make you walk on water. I have been running the same oil at 32/1 and am getting sick of the spooge all over everything so I was going to bump it up to 40/1 but after reading the bottle I wasn't sure if I might as well go to the 53/1 that they say. Has any body tried this before? What the hell could it hurt? Other then the complete top end? :?
Mr. Wibbens
aint gonna help your spooge problem
Mr. Wibbens wrote:aint gonna help your spooge problem
So what would? It's not just a little around the pipe, it's all over.
Mr. Wibbens
Jet your bike properly
And repack your s/a if it's aftermarket
I went thru the jetting thing and went down to 155 and 42 with no decrease in spooge. that was also with a fresh repack. Plug looks good and it has been running good.
kdxmaniac
Post by kdxmaniac »
you need to check your silencer...... my ktm 300 was was spooging bad......repacked the silencer{fmf} and all good now.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Are you running fuel with ethanol in it? ... a mechanic should be asking these questions!
