Sticky clutch?
Posted: 08:39 pm Jul 02 2010
Does your clutch ever "stick"? I guess....maybe normaly when its pretty cold, like the first time I click her into gear, and not every time, but often enough, I"ll put the clutch in, click her into gear...then the clutch lever just goes limp and the clutch is stuck in... if I keep it in, then hit the shift lever into neutral and back to first, all is fine...
Maybe its the gearbox oil?? Clutch seems to perform perfectly other than those few times it does this....
Bike is an 06' stock 200...
Thanks!
Thanks!
