Page 1 of 2
Fork Guards and other various sundries.....
Posted: 10:17 am May 12 2010
by Sapphire
I would like to get some Fork Guards for this 06’ 200. Mainly…well…because they look cool! I am not seeing anything that is built for the KDX…is there any product I can find that will be fairly easy to adapt/modify? I’ve got the technology…just need a starting point! It will be a couple years min before I go for the KX conversion....
How about a disc guard? Rear disk guard? Skid Plate? Recommendations?
And yeah...I"ve "searched" both here and TT...
Posted: 10:27 am May 12 2010
by scheckaet
then search again...
Posted: 10:29 am May 12 2010
by scheckaet
fork boots is all I've seen on rsu.
skid plates, u checked Monkeybut?
disk guard, don't run any but i think ufo made an ugly one for the front.
For the rear there are some but you'll have to search...
Posted: 11:03 am May 12 2010
by Sapphire
I should have been clearer... I am looking to put a set of those "blade style" fork guards on....
I see Fredette has a front disc and sorta "lower" fork guard available.
Skid plates are all over...I was just looking for recomendations...
By the way Scheck....I am thinking the DRZ SM is the Perfect second bike to own!!!
Posted: 11:11 am May 12 2010
by scheckaet
yup it's a fun bike to have in SM form to tool around. Not so great for long distance
Don't think anyone makes a blade style (like a kx usd fork guard for the rsu) you might be able to fab / adapt one.
Posted: 11:36 am May 12 2010
by Sapphire
If anyone has a suggestion of what model might be closest? I am not familiar with the forks of all the different bikes… I’m sure I can mod something to work… but I have to try and get to the closest starting point!
By the way, what is the "rsu"?
Posted: 11:37 am May 12 2010
by Colorado Mike
Right Side Up.
Posted: 11:43 am May 12 2010
by scheckaet
also referred as spaghetti conventional
Posted: 11:52 am May 12 2010
by Sapphire
What year did the KX's still have RSU?
Posted: 03:14 pm May 12 2010
by Mr. Wibbens
Posted: 03:21 pm May 12 2010
by Sapphire
I'll get it worked out eventually... too rainy to ride today (the soil here is NOT good to ride on wet... it is clay and is quite nearly IMPOSSIBLE to get off anything....so easier to wait for it to dry...which is never long)
Posted: 03:43 pm May 12 2010
by Mr. Wibbens
We ride clay all the time
Posted: 03:47 pm May 12 2010
by scheckaet
a new rider will always have lots of trouble in slime at the beginnig...
Posted: 07:55 pm May 12 2010
by Sapphire
I actually wasn't referring to the riding...but the mud build up on the bike... the clay we have, called "Gumbo" will actually build up on your tires till they wont fit under your fenders!!! When you get done, a pressure washer and about $12 in quarters gets some of it off... but you really have to work it with a stick. I'll see if I can dig up a pic of the gumbo...
Is that what your clay does Wibbens? I grew up in clay country also, but it was different clay than this.....
I haven't ridden in 24 years... but from the age of 5 till 15 I rode a LOT... and surprisingly to me...it was like "riding a bicycle"...
HEy... A guy told me to pull the snorkel out the air box...when I opened it up, he said, pull the whole lid off... is that cool? It doesn't need the lid at all? And...there is a little black electrical box screwed to the lid... whats that???
Posted: 08:00 pm May 12 2010
by Sapphire
"The Missouri Breaks National Back Country Byway consists of gravel roads and unsurfaced roads that become totally impassable when wet. Check the weather, and do not attempt to travel the Byway if wet weather is threatening. Even a brief shower can turn the dirt roads into “gumbo” which is extremely slick and binds tenaciously to everything it contacts. Even a 4-wheel drive vehicle, the obvious choice for most back country travel, is no match for the clinging mud. "
Thats the chit right there... nasty... we were pulling a utility trailer behind my truck...4wd on a FLAT surface and barely moving...ended up getting turned around and back to the highway...the trailer was "skiing" behind us cause the wheel wells filled up and locked the tires up...
Posted: 12:27 am May 13 2010
by scheckaet
yup you can remove the lid of the air box to let the engine breath better, you'll need to rejet accordingly. You can relocate the black box on the front of the air box.
The draw back is a more throaty sounds, some don't like it but I don't mind.
Also if you ride in very dusty condition, you'll need to clean the air filter more often.
Posted: 12:38 am May 13 2010
by Mr. Wibbens
I like my version better
Stays cleaner, less noise, but still has plenty of pull
Posted: 12:45 am May 13 2010
by scheckaet
or you can do that. They're from RM right?
Posted: 06:48 am May 13 2010
by KarlP
Wibs way looks like the way to go.
About double the intake area from stock, I'd say.
Posted: 07:29 am May 13 2010
by Sapphire
Right on...I'lll make some adaptation or remove it or whatever...was just conderned that the dust would have a very direct route into the filter... but breathing is best...
