X-ring master link removal tips
- wanaride
I've taken the stock chain off lots of times with no problem, but I tried for the first time yesterday to remove my new X-ring chain, and I could not get the master link apart. (I'm trying to remove the swingarm and linkage for greasing.)
Channel Locks and needle-nose pliers didn't do the trick; I can get the clip off but I can't pry apart the link. Does anyone have any tips I can try next?
I love someone with autism!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 50 Mini Adventure
2006 KTM 250XCW
2003 KDX200
2006 CRF70
I use a flat tip screwdriver to alternately pry at each end of the removablel link plate. Once the link begins to move outward on the pins it moves relatively easy as long as you don't bind it. Don't get crazy with the prying though or you could bend the link plate.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- m0rie
Don't forget to keep an eye on the orings while your prying the master link apart. They have a bad habit of disappearing when the master link comes apart...
- skipro3
Re: X-ring master link removal tips
You don't NEED to remove the chain to do this job.wanaride wrote: (I'm trying to remove the swingarm and linkage for greasing.)
- wanaride
Yes, I realize that, but unless I either (a) disassemble the chain guide, or (2) remove the front sprocket, the swingarm will still be attached to the bike via the chain. And yes, I can still do the job with the chain/swingarm connected to the bike...I just thought I was missing something simple.
And I tried the screwdriver trick, with a Craftsman no less...the tip broke.
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 250XCW
2003 KDX200
2006 CRF70
Use Snap-On.... and it won't Snap-Off....
- Colorado Mike
- Mr. Wibbens
Get a chainbreaker and be done with it!
- fuzzy
It's not real good to break the chain every time you need to remove it. They're good for removing links, etc when you first get a chain, but then the master link is the best for removal/re-installation. The master link is the weakest link the in the chain. Any link you touch w/ a chain breaker will become a weak link as well.
I can't say for sure wether it really matters that much on a #520 chain that is used for trail riding. Moto-X...Prolly. My karts w/ 40-50hp through a #35...heck yeah....Until I could find some #35 master links I was throwing chains at the 'break' point quite often(if I broke them after initial installation/stretching)....
- Mr. Wibbens
I use the chain breaker to push the pins out of the master link
- skipro3
Remove the chain guide from the swingarm before you take the swingarm off. Two simple bolts is all there is. That is MUCH easier than removing the master link and besides, it's much easier to service the swing arm with that guide removed anyway.
I am of the camp that you never reuse a master link. Once on, if it needs to come off, replace it with a new one. (Keep the old in case of an emergency)
Man, you guys are making way more work out of taking the swingarm off than is needed. I can remove the swingarm in about 5 minutes this way. Am I the only one who leaves the chain whole when serviceing the swingarm?!
Say it isn't true!
Say it isn't true!
- wanaride
Skipro, I am sad to say that if there is a hard way to do something, I'll leap over the easy way to find it! Maybe I should change my user name to "hardway".
This is all great advice. I'll plan to just remove the chain guide in the future (and now too since I still haven't gotten the chain apart)! The chainbreaker for pin pushing is a great idea too, along with keeping the link on the rear sprocket. Man this site rocks!
2006 KTM 250XCW
2003 KDX200
2006 CRF70
2006 KTM 250XCW
2003 KDX200
2006 CRF70
- fuzzy
