Deep Water stalling - which carb vent hose to route "up
ihatefalling
Post by ihatefalling »
Hey guys....doing the AMA Renfro Valley ride this weekend. Anyone else going?
Expecting some deep water crossings. I know there's a carb vent hose that can get water in it when crossing deep water....thus causeing the bike to stall. Can you tell me which one it is? Real plain talk too....like "Back of carb, drivers side, lower hose" if you don't mind. :grin:
Or maybe even post a pic :grin: :grin:
I DO NOT want the old gal stalling when going through water like this...
go to 2:30
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
That water crossing is SWEET! Looks like the water was moving pretty fast too!
I think you just run the two lines from the top of the carb up into the airbox. The last one is just for the float bowl drain.
RBD
Post by RBD »
It is my opinion that the carb vents (all) should go down and unobstructed after it leaves the carb. If you run the vents up, gas can get trapped in them and this can cause stalling.....
Ron
ihatefalling
RBD wrote:It is my opinion that the carb vents (all) should go down and unobstructed after it leaves the carb. If you run the vents up, gas can get trapped in them and this can cause stalling.....
Ron
I thought about that too. Seems like maybe you could put a " T " fitting real close to the carb (high above water), and then you can vent up and down....
Well, this all goes back to a problem I've had of sometimes stalling when going through somewhat deep water (1.5 - 2 feet). SOmeone told me I was stalling because those vent hoses were getting blocked by the deep water. ANy other feedback? The drain on the bottom my airbox seems pretty tight....no water getting in there.
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
Some guys just run them into the airbox....
I run all of them but the carb overflow in the air box, never seem to have any issue.
I didn't think you could run them up now that I think about it. When I get gas in those lines if I hold them above the carb, they won't drain out, like there's a check valve in there or something. I think Ron is right, they need to be down in order to work.
canuckhybrid125
Post by canuckhybrid125 »
I had one of those filters that hooks up to the vent lines and they kept filling up with gas,so I took it off.
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
dfeckel
Post by dfeckel »
I wonder if the fuel starvation with the underwater vent hoses applies only to carbs with the four vent lines?
David Eckel
