'97 KX125 Carb on a KDX220?
Postby Jim B » 11:32 pm Apr 22 2010
I've got a spare 36mm. PWK off of a '97 KX125. Would this be too big for a KDX220? I'd have to imagine it would help the top end power quite a bit. Would it kill the bottom end power?
If I were to use it, I'd use the KDX slide and needle (I'm assuming they're different but at this point I haven't checked).
Jim B
Has thanked: 15 times
Been thanked: 19 times
Postby fuzzy » 10:13 am Apr 26 2010
Sure it's a 36 and not a 38? The 36 uses a 38mm body...which will physically be too big for the KDX fit-wise(this is why RB bores the KDX carb to 36). It just so happens that I'm in need of a 36mm PWK for my WR. I have a 35mm KDX 200 carb I'd trade....Still has KX throttle/etc attached. I have the opposite problem with my WR...35mm doesn't fit the boots right.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
fuzzy
Has thanked: 0 time
Postby Jim B » 11:19 am Apr 26 2010
It measures just a little over 36mm on the inside. The factory manual lists a '97 KX125 (what this carb came off of) as having a 35mm. and the '98 125 as having a 36mm. Maybe someone swapped a '98 carb onto the '97. :hmm: It's definitely not a 38. I haven't had a chance to see if it will fit into the KDX inlet and outlet boots.
Jim B
Postby RBD » 12:30 pm Apr 26 2010
The carb size is measured at the slide area. When you look into the carb, you will see an area that has been machined where the slide intersects the bore, this is where it is measured.
For casting reasons there is a bit of taper to the bore of the carb and can measure about 1 mm larger at the mouth, but it is the smaller machined area of the bore that determines the size of the carb.
Ron
RBD
Has thanked: 0 time
Been thanked: 0 time
Postby Jim B » 01:29 pm Apr 26 2010
Thanks for the info, Ron - I appreciate it!
Jim B
Postby KDX4ID » 05:06 pm Apr 27 2010
A PWK that old is probably in need of a rebuild or in the case of my KDX replacement.
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
KDX4ID
Has thanked: 0 time
Postby Jim B » 05:07 pm Apr 27 2010
I'd definitely rebuild before installing it.
Jim B
Return to KDX General Q&A
Who is online
Users browsing this forum: ericr, Google [Bot], Majestic-12 [Bot] and 5 guests
