Throttle cable clip
pdiddy
Throttle cable clip
Post by pdiddy »
Ok, it has me outsmarted. I get it partially on, but I cannot seem to get it to seat securely into the groove. Also the right side of the clip is bent out and doesn't seem to want to bend in to make it a rounder 'U' shape.
So, how do I get this:
Onto this:
RB Carb and Head mods, 2002 KX 125 Forks, air box lid removed, VForce 3 Reeds, PC Platinum 2 EC, gripper seat cover, Renthal bars, Fredette chain guide, and some other odds and ends
Mr. Wibbens
Post by Mr. Wibbens »
Least it's in focus :wink:
But I have not a clue
Don't think my E has anything like that
RBD
Post by RBD »
The flat side of the clip lays across the slot in the brass barrel and the rounded side goes around the back side of the brass barrel. It holds the cable in place. If you are using an aftermarket cable, it may not have the necessary groove in it to make the clip work.
Ron
canuckhybrid125
Post by canuckhybrid125 »
Image[/img]
Hope this helps
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
Little Jeff
Post by Little Jeff »
I actually just used safety wire for mine and it works just fine.
Little Jeff
Riding with your buddies and an adventure, riding with certain individuals is an ordeal.
