Preload Spacers?
Preload Spacers?
Today I redid my stock forks. I know about the KX swap, that's going to wait. I'm not a good enough rider to need those right now, nor do I have funds, etc.
Anyway, I'm 185 with gear, my bike has the .38 springs, and fresh 5W oil. I did the base valve shim stack mod today, removed 4 of the 10 shims, now running 6. I read on cutting my own preload spacers, but with the correct springs, is that really nessicary? I guess that's what I'm trying to determine. I ride mostly rocky terrain, so some soft suspension is important to me. Input appreciated.
Yeah... the stock preload spacers are way too long. You only want about 5-10mm of preload on the springs.
Do I need to make entirely new ones, or can I just chop the stockers down? Also, where's the cheapest place to find a new base valve assembly? (See rebuild thread.)
some use PVC from the hardware store.
Ya that's what I was referring to. I think that's a good route to take, I might even have some lying around.
chris-1742
Post by chris-1742 »
Slick Nick, Carver did a great write up on the pre-load mod awhile back.
Search for it. 1" Schedule 40 pvc. I did the mod last season with noticable results (positive). Pre-load was about 22 stock and is now at 8 mm and also did the shim removal (-4) with a blend of oil to 7.5w.
Good luck on the base valve!
Old guy on 04 kdx 220
RB Carb and head
And all the rest.....
I'm going to do the preload spacer mod as soon as I get my forks back together with the new base valves. I did the shim stack mod (-4 also) already, and I'm running Motorex 5W oil.
What did you notice as a difference? Softer? Were the forks easier to bottom because of this?
chris-1742
Slick,
The biggest difference was the front absorbed and tracked better...I went to 7.5w to slow the rebound abit. I also have the clickers out to 9 which seems to work well for me...200 lbs. w/ gear. Bottoms out only on a very harsh hit at speed..play with your oil level to get the results you want...we all like a slightly different feel.
RB Carb and head
