Just picked up a 04 kdx 220 and when i test rode it it seemed fine except for a slight hesitation mid range. when i got it home and was able to give it a better ride it is definitely boggy at low rpms but will stand right up 1/2 way through the power band. I went to clean the air cleaner and found the cover to the air box was missing. just wanted to know if that is some sort of modification ( I think the only mod on the bike is a gnarly gold pipe.) and what it would be doing to the performance of the bike. I will be cleaning the carb and replacing the plug and the usual maintenance but i was hoping to get some feed back on the air box cover and maybe some ideas on the bogging problem.
Thanks for any input you might have... Rich
just bought a 04 kdx220 need some advice.
Yep... a very common mod is to lose the airbox lid. Helps the bike breath and make more power....
What is your air screw set too?
- scheckaet
lid missing? common mod.
bog is most likely a jetting issue. jet it properly, read the sticky on how to
cleaning the carb is a good idea.
It's a 220: if you still run the stock piston: replace with an aftermarket ASAP (most use a wiseco). If you don't you might grenade your engine. do a search about 220 piston.
Check your linkage and swing arm bearing and grease them.
Go ride
Go ride
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Thanks... that's just the info i was looking for.... for the most part.... whats up with the PISTON....... I guess i found this forum a little late, I had a 92 kdx200 and the thing was bulletproof from the day i bought it used. all i heard about the 220 was the same so i grabbed this one . It was a little beat up but for $1200 bucks i thought it was a good deal. I will search around about it. Thanks for the help and the heads up.... Rich
- scheckaet
the 200 piston has no issue, but for some reason the 220 stock is known to fail, crack....grenade....
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
