Carb Float ???
Tomm9050
Carb Float ???
Post by Tomm9050 »
Does this sound right?
I adjusted (raised) my carb float level, bent the tang DOWN a bit, it was low, and when I put it all back together, it was not getting gas, gas wouldn't flow.
I lowered the float a bit and it seemed to fix the problem.
So, if the float level is too high, will it prevent gas from getting
to the bowl?
Thanks!
1992 KDX 200
stock needle
45 pj
155 main
3rd clip
Not really.... that sounds backwards of the way it should work. You really should measure it per the manual but add 1 mm to keep it from peeing.
Tomm9050
Post by Tomm9050 »
That's what t thought. I did notice that I measured the height without tipping the float. I guess I'll have to redo it
thanks
1992 KDX 200; RB head; Fatty pipe; stock carb; Stock silencer
40 / 150 / CGK pos 3
ihatefalling
Post by ihatefalling »
You said pee :cool:
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
