compression problems
Posted: 08:43 am Mar 04 2010
by KDXsg
Hi, i just manage to start my 92'KDX 200 and ride for a while....stop it and after afew days, went to start it again but found that there is no compression to it. any idea what could be the possible problem? thanks.
Posted: 10:30 am Mar 04 2010
by Indawoods
Kicker gear slipping?
Posted: 10:08 pm Mar 04 2010
by bronco95tgp
Did you happen to check the spark plug?
Posted: 11:10 pm Mar 04 2010
by KDXsg
Thanks for the advices. I will go and look at the two areas.
Posted: 05:32 am Mar 07 2010
by KDXsg
Guys, its kinda strange. i just managed to feel a bit of compression and give a hard kick. it start from it! after which I let it idle for a while and rode for a while. kill it then using the kick starter to feel for the compression and its back to normal again.
Posted: 07:54 am Mar 07 2010
by Julien D
sounds like your kickstart ratchet gears are worn and not engaging consistently. Had the same problem on my '89 when I brought it home.
