Removed the carb from the bike and bought some cleaner.
Removed the float bowl, jets, and needle.
Do I remove the float and float valve as well? And also, how should I go about cleaning it?
How to clean carb?
- Mr. Wibbens
Better to remove the float and valve before that pin comes loose and you lose it
- Tedh98
I take everything apart.
Even this thing that you need a security torx bit for
I soak it all in degreaser and then toothbrush all the grime and crud off.
I'll then use the carb cleaner in the can to blow out and clean all the passage ways. Finally I'll run some fine wire through the jets to make sure nothing is stuck in there.
- RBD
- Tedh98
