Sunline V1 levers (Brake & Clutch)
Posted: 09:02 pm Feb 21 2010
by summitrider04
Will they work? -- On their website, the KDX 200 (mine is an '03) isn't shown as an application, only KX's.
Has anyone used them?
Thanks
Posted: 10:58 pm Feb 21 2010
by bronco95tgp
I've got the ASV F1's.. they are comparable I guess but half the price? If you want to spend $140 on levers you might check out the ASV F3 Holiday pro pack that comes with both levers, fancy dust covers, and all sorts of stuff.
http://www.locomx.com/Levers-s/255.htm[/url]
Its at the very bottom right on that link.. I have two buddies that have the pro series holiday pack F3 ASV's and they are different colors and such but I am very happy with my F1's they installed and adjusted easily and fold back just like the more expensives ones
Posted: 02:24 am Feb 24 2010
by summitrider04
Nice, that's a great deal.
The reason I was asking about the Sunline is I have an account with sixsixone so I can buy them at cost. I called them up and they said to cross-reference the KDX levers with the same year KX 2 stroke and see if they are the same. I haven't looked into it very far except for looking at the ASV application chart they look like they are the same so the Sunline should work.
I have Acerbis ralley pro hand guards and after finding out I will have to drill out the welded bar end plug I was looking into buying a new handlebar or just getting some "unbreakable" levers. I'll probably just dremel out the plug.
Thanks for the help
Posted: 12:23 pm Feb 24 2010
by Green Hornet
I use them & they work well
Posted: 05:55 pm Feb 24 2010
by bronco95tgp
Summit, might be a good time to saw your bars if you want them more narrow instead of having to drill and dremel..
