Broken Oil Drain Plug
chris-1742
Post by chris-1742 »
Oh I`m pissed....Just putting the final touches to a COMPLETE winter rebuild including RB Head and Carb mods and I snapped off the Magnetic drain plug.
I have started the drilling for a easy out and the remains of the stud is starting to turn with the bit (towards the Inside of the case).
Question, can that stud be retrieved from the clutch side cover should it continue into the case OR will I have to pull the engine and split the cases?
Hoping for the best case but dreading the worst.
Thanks guys!
Old guy on 04 kdx 220
RB Carb and head
And all the rest.....
scheckaet
Post by scheckaet »
I think if it goes in the case, you won't be able to get to it unless you split the case. If it's loose, can't you get it out now the regular way?
good luck
Mr. Wibbens
Post by Mr. Wibbens »
How the hell do you snap off a drain plug?
scheckaet
Post by scheckaet »
with STRONG gorilla hands :lol:
Colorado Mike
Post by Colorado Mike »
If it turning that easy try reversing the drill or if you have enough of a hole maybe the easy out can get a grip.
If it gets up in the case you're in for a lot more fun.
Mike
'04 KDX220
chris-1742
Scheckaet,
There is nothing to get a hold of to back it out....it sheared off approx. 1/4" inside the case.
I`ll go give it a try with something...
Thanks
Chris
RB Carb and head
chris-1742
Mike,
Not enough of a hole yet to get the easy out started.
I did get a #3 phillips to get a bite and did get it reversed to just past flush of the case, no further.
I will keep at it... I don`t want that much" more fun "!
Thanks
Chris
RB Carb and head
chris-1742
GOT IT OUT!
Continued the drilling then used the easy out. Any recommendations for flushing the case?
Wibbs....ever turn right when you should have gone left.....
I won`t be doin that again!!
Thanks guys and have a good weekend!
RB Carb and head
scheckaet
Post by scheckaet »
you're lucky you didn't break the case or striped the plug hole. I keep it snug, can't remember how much torque it is (14flb?)
Mr. Wibbens
Not when I'm working on the drain plug :wink:
Is this some aftermarket plug? I can't really see the stocker snapping off
Colorado Mike
Congrats, you got off lucky. My kid did that and stripped the case. I ended up putting a timesert in, but that was mighty expensive for the kit. Glad you got it. I was about to suggest that Sears craftsman extractor kit on the infomercials.
Mike
'04 KDX220
chris-1742
Yeah, I believe it was a Tusk magnetic. They appear to have a steel tip inserted in the bolt end which is the magnetic portion.
The bolt sheared at the transition.
And Yes, I did get lucky.
RB Carb and head
ihatefalling
Post by ihatefalling »
glad you got it out....whew
2005 KDX 220
R&B Carb Mod
R&B Head Mod
Fork Swap - 99 KX125 Valved for B woods plush
FMF Gnarley
Airbox Mod
Tagged
