On the 220, are the two mounting bolts that go through the cylinder head the same lenght? If not, does anyone know which bolt goes up front and which one goes in the back.
Thanks,
John
cylinder head mounting bolts
- Varmint
- Varmint
Virtual Varmint,
I just went out to check the nuts and they are still tight...I will still swap them around tomorrow night and get them back to spec. One question, I rode the bike for about 20 minutes the other day before I noticed they might be swapped around. Could this potentially have done any damage? If so, what should I check for?
Thanks for the help,
John
John
- Varmint
Nah, if they held the engine in there for your ride, you're good. I'm sure you had enough meat on that front bolt to go for one ride.jbowens2401 wrote:Virtual Varmint,
John
That may be a good bolt to apply some locking agent. I didn't.
