Page 1 of 2
How do you start a KDX?
Posted: 09:30 pm Feb 07 2010
by river
OK, believe it or not I have not tried to even start my KDX since I got it around Jan 5. My doc did not give me the OK to ride yet but I am off the crutches so I took the cast off and tried to start it.
I have BAD news: the kick starter slams into the foot peg. Ouch!
WHAT? Jeez!!
But, no start. It ran fine when the seller rode it around, and restarted fine. I asked him not to start it the day I came and it felt cold when he kicked it over. But that doesn't mean he didn't get it going before I arrived. Anyway, I just loaded it up after he rode it and put it in my storage unit til now.
With the throttle open, it gives a hollow sound when turning over. With throttle closed, it just sounds dead. No sign of catching at all. Probably kicked 50 times or so. Getting gas, in fact the petcock leaks like a sieve. Ordered new seals.
So....I can't find the choke either. Yeesh, I'm a dummy. Two strokes have chokes, right? I seem to remember from my tire store salesman days that Lawn Boy mowers had chokes, and they were two strokes.
Anyway, even if the sucker didnt' start, it was a blast to finally stradle it and start kicking, except the footpeg. Compared to my XR it feels like a bicycle.
Any carb pics around here that might show a choke? I hesitate to get the online manual, I read it has errors (?) and want to buy a hard copy manual when a good deal comes along. Any suggestions on what to try?
Thanks all.
Posted: 10:15 pm Feb 07 2010
by bronco95tgp
the choke has a green circle around it.. only difference is the one on your bike wont have the green circle around it!
Posted: 10:18 pm Feb 07 2010
by river
Hm, I thought that might be it, but I'm used to a lever. Do you screw it in? Anyway I'll figure it out now that I know.
Posted: 10:19 pm Feb 07 2010
by pinitwot
you may try spraying some starter fluid in the air filter, not the best for it. but its better than not running. i dont no if its really cold where you live it will be harder to start
by bronco95tgp
I rode my KDX around my neighborhood a bunch after I had broke my leg in the bull ridin.. luckily it was my left leg so I could sit on the bike and kick it. I could crutch out to my bike and leave the crutches where I could ride right back to them. Good thing I never stalled! Shoulda got a pic Im sure I looked like a goon
Posted: 10:26 pm Feb 07 2010
by Indawoods
river wrote:Hm, I thought that might be it, but I'm used to a lever. Do you screw it in? Anyway I'll figure it out now that I know.
Pull it UP!
Posted: 10:31 pm Feb 07 2010
by river
OK, I'm a bonafide dummy.
But soon I get to ride, so I'm a happy bonafide dummy.
Posted: 10:51 pm Feb 07 2010
by Julien D
I assume it started once you turned the choke on?
Posted: 11:10 pm Feb 07 2010
by river
Nope, it's in my storage unit and I'm back at home. Will report back...
Posted: 01:55 am Feb 08 2010
by river
>|QBB<[/url]
bronco95tgp wrote:the choke has a green circle around it.. only difference is the one on your bike wont have the green circle around it!
By the way, thanks for the pic! Naturally, the circle is green.
Posted: 11:30 am Feb 08 2010
by bronco95tgp
No problem river, just lift that UP like Inda said and it should stay in place, then let her warm up a bit and push the choke back down. Always green, grave digger/kawasaki geen!!! Don't mind the other parts of that photo as the carb is partially taken apart from the reed cage there. hopefully cyclepedia wont sue me for posting that picture.
Posted: 12:13 pm Feb 08 2010
by Fieldie
Wow, here I am in Aus having the same drama at the same time. I bought my bike of ebay and hadn't started it since collecting via a mate who was 2 hours closer to the seller than I was.
My kick start hits the foot peg too. When you have sorted the starting issue, this much travel will be plenty...
Yesterday the first thing I did was check I had fuel flow. (I was turning the fuel tap the wrong way. Sorted now!)
Then I double-checked that I had spark. Took the spark plug out and reattached the lead to the top. (it's really important to make sure the fuel tap is turned off for this bit!!!) Hold the thread of the plug against the outside of the exhaust expansion chamber. Since the plug wasn't in, there was low compression so could kick it over by hand. Spark was good (a new spark plug for $5 is cheap insurance)
I then removed the hose clamp around the rubber boot between the carby and air box to get better air flow (I had cleaned the air filters a couple of weeks prior). With that open, I squirted some starting fluid as a last resort. With my six year old son crossing all his fingers, arms & legs for luck I gave her a kick and she started briefly.
I sprayed for another second or two and kicked again. She sprang to life and stayed running as long as i kept the revs up. Wooooo-hooooo!!!!
I gave both of my kids a quick dinky around the block then put her back in the shed.
I know the starting fluid may not be great for a 2 stroke engine but I had it at hand and it worked when used with caution. A spray bottle with a mix of petrol & 2 stroke oil should probably do the trick!
I hope this helps you out!!!!!
I saw the choke pictured on my bike but mine springs straight back down when I let it go. I will try it again but is there any trick to it?
Posted: 12:15 pm Feb 08 2010
by Indawoods
For the record... most all KDX kickstarters hit the peg.
Posted: 12:23 pm Feb 08 2010
by Julien D
Pull it a little further, it should "click" into place when fully extended.
Posted: 01:40 pm Feb 08 2010
by DirtBikeDad
Mine was doing the same thing a few months back. Removed the choke assembly and cleaned it and the hole from whence it came with a little fresh gas (not premix) and a lint free rag, squirted a dab of wd-40 on the moving parts and no more issues after reassembly. I've heard (and my next step had this not worked) that if the rubber boot that holds it in place (hence the "click" mentioned in an earlier post) is overly worn.....then a strategically snugged small sip tie at the base of the boot could set things right.
Posted: 03:22 pm Feb 08 2010
by frankenschwinn
My choke was hitting the fuel petcock when I got it. It would not go up far enough to lock in the up pos. I loosened the carb boots and rotated enough to give the choke the room it needed.
My kick starter hits the peg too.
Posted: 04:57 pm Feb 08 2010
by fuzzy
I'm trying to remember a dirt bike I've kicked where it doesn't.
Posted: 10:57 pm Feb 08 2010
by river
fuzzy wrote:I'm trying to remember a dirt bike I've kicked where it doesn't.
Pretty sure it doesn't on my XR650R.
Posted: 10:58 pm Feb 08 2010
by Dale
I always lean my 2 strokes over about 45 degrees until fuel flows out the hose. Then choke it and it fires in two kicks.
Posted: 10:45 am Feb 09 2010
by fuzzy
Would be curious. Looks like it would in the below pic, but may take a huge stroke to get there. Kickstarters need a stop, and most bikes just use the peg for it by design.
http://dirtbike.off-road.com/dirtbike/d ... 5741/8.jpg
