suspension tunning?
pinitwot
suspension tunning?
Post by pinitwot »
i just found this paper along with the stuff with my bike and and it says: Fredette Racing Products Suspension Tuning.
so i called the owner and he said he did take the bike in about 3 years ago and got it done.
here is what the paper says:
shock:
spectro weight: u-l
spring weight: stock
sag: set to 3 and 3/4 inches
compression clicks out: 9
rebound clicks out: 9
nitrogen PSI: 180
Forks:
Spectro weight: 125/150
oil level: 100mm
spring weight: 38
preload: stock
compression clicks out: 8
Rebound clicks out: 0
so i would like to no what is this suspencion set up for? could i ride it like this on a mx track or would i bottom it out on the big jump?
i weigh around 150lb
thanks :grin:
zomby woof
Post by zomby woof »
150 lbs?
You should be alright.
Ontario, Canada
