Rear shock...I need way too much preload.
Posted: 01:00 pm Feb 05 2010
Good Morning,
I am new to this forum and relatively new to the KDX. . I recently purchased a 1996 KDX that was properly moded. My problem is that inorder to get the rear sag right I have to crank the preload down almost 3/4 of the available threads. This makes for a harsh ride. In the past I would just jump up to a higher spring rate, but according to the rate calculators at 205 with gear I should be fine on the 5.0 stock spring. There are no signs of leaks from the shock. Any ideas?
Thank you for your time in advance.
GR
GR
