steering damper
steering damper
what effect will worn steering dampers under the bar clamps have? Whats the best way to tell if they need replacing? Are o.e.m the only option for replacement?
steering dampers
I looked at my friends 22oe and his is an 02, two years older. His bars were pretty tight when i would pull against them on the steering stop< mine would move about an inch. I ordered a set from brp. Thanks for the info...
- Colorado Mike
