Advancer Shaft Removal
Varmint
Post by Varmint »
I'm trying to the the cylinder off and I can't get a good grab on the bolt behind the advancer shaft. Will removing the little phillips head free up the shaft for removal? Will anything drop into the cases?
The manual doesn't even mention to remove the shaft!
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Why would you have to remove it? :hmm:
Varmint
Post by Varmint »
Indawoods wrote:Why would you have to remove it? :hmm:
The nut on the cylinder is unreachable with a wrench or socket. The frame or the shaft is in the way.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Got a pic?
Varmint
Post by Varmint »
>|QBB<[/url]
Indawoods wrote:Got a pic?
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Varmint
Post by Varmint »
Too scared to stick a 12 point on it. Maybe I should go out and buy a 6 point wrench.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I use an offset 12 point closed end wrench....
Take that clutch cable loose too and get it out of your way.
Varmint
Post by Varmint »
I need a set of these in metric flavor...
I ran out to sears and they were closed. Just my luck. Going to the bar instead. :partyman:
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Varmint
Post by Varmint »
Indawoods wrote:I use an offset 12 point closed end wrench....
Ha, you posted while I was doing 65 in a 35 trying to get to sears before 9. Too bad they close at 8.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Mr. Wibbens
Post by Mr. Wibbens »
Take right cover off?
Varmint
Post by Varmint »
That'd work too!
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Mr. Wibbens
Re: Advancer Shaft Removal
VirtualVarmint wrote:I'm trying to the the cylinder off and I can't get a good grab on the bolt behind the advancer shaft. Will removing the little phillips head free up the shaft for removal? Will anything drop into the cases?
BTW, If it is anything like an E you have to take the cover off to remove the shaft.
Once the cover is off your problem is solved :wink:
Just watch the shifter return spring and kicker spring when you go to put it back together
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I never had to do that on mine.
Varmint
Post by Varmint »
I'm gonna buy a set of offset wrenches. I love having a reason to buy tools!
How can you possibly torque that bolt on reassembly?
Thanks guys.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
scheckaet
Post by scheckaet »
VirtualVarmint wrote: How can you possibly torque that bolt on reassembly?
Use the hand torque wrench :mrgreen:
Varmint
Post by Varmint »
scheckaet wrote:>|<>QBB<
Need onadoze torque wrench extender adapter jobbers.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
Brian
Post by Brian »
I use the torque wrench on the nuts I have access too and then put my box end wrench on them and feel how much force it takes to move them and then I apply about that much force on the nut I can't get the torque wrench on. Once you have gone around them a time or two they should all be torqued about even.
