ODI Lock-On Grips
pdiddy
ODI Lock-On Grips
Post by pdiddy »
I run lock on grips on my mountain bike and love them. I see someone has finally made them for dirt bikes too. However, rocky mountain says it is machine specific and doesn't list the KDX. What in the world is machine specific about these? I am considering ordering them for a KX 125 and putting them on, my bike is about to have a KX125 front end anyway. Thoughts?
http://www.rockymountainatvmc.com/produ ... icleSelect
muddertrucker
Post by muddertrucker »
Throttle grip molded directly to an O.E. spec throttle tube.
Find a model that has the same throtle tube as the KDX and you're all set.
I've thinking about getting a set of these for my bike too.
4 wheels move the body 2 wheels move the soul
Gallery!
pdiddy
Post by pdiddy »
Hmmm, the part numbers don't seem like an exact match. In looking at the OEM catalogs, the throttle tubes between the KX and KDX share some of the same part numbers, but are not identical. On Rocky Mountain, the Motion Pro throttle tubes between the KX and KDX differ by 1 digit 1015250006 vs 1015250007.
RB Carb and Head mods, 2002 KX 125 Forks, air box lid removed, VForce 3 Reeds, PC Platinum 2 EC, gripper seat cover, Renthal bars, Fredette chain guide, and some other odds and ends
frankenschwinn
Post by frankenschwinn »
pdiddy wrote:Hmmm, the part numbers don't seem like an exact match. In looking at the OEM catalogs, the throttle tubes between the KX and KDX share some of the same part numbers, but are not identical. On Rocky Mountain, the Motion Pro throttle tubes between the KX and KDX differ by 1 digit 1015250006 vs 1015250007.
Please post your findings as I would love to run Lockons as well
KarlP
Post by KarlP »
You can use some KX throttle assemblies.
I am currently using a '95 throttle assembly. That is everything that goes on the handlebar and a '95 KX 125 throttle cable.
I can't speak for other years. I found this by mixing and matching parts during a hybrid build.
The KX throttle assembly has a better mechanism, IMO, than the OEM KDX.
It also has a slightly shorter pull.
You know, when you buy an OEM throttle tube, it has the grip molded on. It was heck to cut off to put the grip on I wanted!
'08 KTM200xc
KX100 for the boy
jbg_3d
Post by jbg_3d »
KarlP wrote:You can use some KX throttle assemblies.
Did you have to modify cable at all? I want to run ODi lock-on grips as well and am going to buy a new throttle tube and cable, just wondering what I should buy?
Tyl3r
Re: ODI Lock-On Grips
Post by Tyl3r »
The throttle tube/grip used on the H series KDX is the same part number that Kawi used on the following:
Model (220):
KDX200-A2 (KDX200) (1984)
KDX200-A3 (KDX200) (1985)
KDX200-C1 (KDX200) (1986)
KDX200-C2 (KDX200) (1987)
KDX200-C3 (KDX200) (1988)
KDX200-E1 (KDX200) (1989)
KDX200-E2 (KDX200) (1990)
KDX200-E3 (KDX200) (1991)
KDX200-E4 (KDX200) (1992)
KDX200-E5 (KDX200) (1993)
KDX200-E6 (KDX200) (1994)
KDX200-H1 (KDX200) (1995)
KDX200-H10 (KDX200) (2004)
KDX200-H11 (KDX200) (2005)
KDX200-H2 (KDX200) (1996)
KDX200-H3 (KDX200) (1997)
KDX200-H4 (KDX200) (1998)
KDX200-H5 (KDX200) (1999)
KDX200-H6 (KDX200) (2000)
KDX200H6F (KDX200) (2006)
KDX200-H7 (KDX200) (2001)
KDX200-H8 (KDX200) (2002)
KDX200-H9 (KDX200) (2003)
KDX220-A10 (KDX220R) (2003)
KDX220-A11 (KDX220R) (2004)
KDX220-A12 (KDX220R) (2005)
KDX220-A4 (KDX220R) (1997)
KDX220-A5 (KDX220R) (1998)
KDX220-A6 (KDX220R) (1999)
KDX220-A7 (KDX220R) (2000)
KDX220-A8 (KDX220R) (2001)
KDX220-A9 (KDX220R) (2002)
KDX250-B4 (KDX250) (1984)
KDX250-D1 (KDX250) (1991)
KDX250-D2 (KDX250) (1992)
KDX250-D3 (KDX250) (1993)
KDX250-D4 (KDX250) (1994)
KDX80-C1 (KDX80) (1984)
KDX80-C2 (KDX80) (1985)
KDX80-C3 (KDX80) (1986)
KDX80-C4 (KDX80) (1987)
KDX80-C5 (KDX80) (1988)
KL250-D10 (KLR250) (1993)
KL250-D11 (KLR250) (1994)
KL250-D12 (KLR250) (1995)
KL250-D13 (KLR250) (1996)
KL250-D14 (KLR250) (1997)
KL250-D15 (KLR250) (1998)
KL250-D16 (KLR250) (1999)
KL250-D17 (KLR250) (2000)
KL250-D18 (KLR250) (2001)
KL250-D19 (KLR250) (2002)
KL250-D2 (KLR250) (1985)
KL250-D20 (KLR250) (2003)
KL250-D21 (KLR250) (2004)
KL250-D22 (KLR250) (2005)
KL250-D3 (KLR250) (1986)
KL250-D4 (KLR250) (1987)
KL250-D5 (KLR250) (1988)
KL250-D6 (KLR250) (1989)
KL250-D7 (KLR250) (1990)
KL250-D8 (KLR250) (1991)
KL250-D9 (KLR250) (1992)
KL600-A1 (KL600) (1984)
KL600-B1 (KL600) (1985)
KL600-B2 (KL600) (1986)
KL650-A1 (KLR650) (1987)
KL650-A10 (KLR650) (1996)
KL650-A11 (KLR650) (1997)
KL650-A12 (KLR650) (1998)
KL650-A13 (KLR650) (1999)
KL650-A14 (KLR650) (2000)
KL650-A15 (KLR650) (2001)
KL650-A16 (KLR650) (2002)
KL650-A17 (KLR650) (2003)
KL650-A18 (KLR650) (2004)
KL650-A19 (KLR650) (2005)
KL650-A2 (KLR650) (1988)
KL650-A3 (KLR650) (1989)
KL650-A4 (KLR650) (1990)
KL650-A5 (KLR650) (1991)
KL650-A6 (KLR650) (1992)
KL650A6F (KLR650) (2006)
KL650-A7 (KLR650) (1993)
KL650A7F (KLR650) (2007)
KL650-A8 (KLR650) (1994)
KL650-A9 (KLR650) (1995)
KLX110-A1 (KLX110) (2002)
KLX110-A2 (KLX110) (2003)
KLX110-A3 (KLX110) (2004)
KLX110-A4 (KLX110) (2005)
KLX110A6F (KLX110) (2006)
KLX110A7F (KLX110) (2007)
KLX110A8F (KLX110) (2008)
KLX110A9F (KLX110) (2009)
KLX110A9FA (KLX110 Monster Energy) (2009)
KX100-B5 (KX100) (1995)
KX100-B6 (KX100) (1996)
KX100-B7 (KX100) (1997)
KX100-C1 (KX100) (1998)
KX100-C2 (KX100) (1999)
KX100-C3 (KX100) (2000)
KX100-D1 (KX100) (2001)
KX100-D2 (KX100) (2002)
KX100-D3 (KX100) (2003)
KX100-D4 (KX100) (2004)
KX100-D5 (KX100) (2005)
KX100D6F (KX100) (2006)
KX100D7F (KX100) (2007)
KX100D8F (KX100) (2008)
KX100D9F (KX100) (2009)
KX100D9FA (KX100 Monster Energy) (2009)
KX100DBF (KX100) (2011)
KX125-C1 (KX125) (1984)
KX125-D1 (KX125) (1985)
KX125-E1 (KX125) (1986)
KX125-E2 (KX125) (1987)
KX125-F1 (KX125) (1988)
KX125-G1 (KX125) (1989)
KX125-H1 (KX125) (1990)
KX125-H2 (KX125) (1991)
KX250-C2 (KX250) (1984)
KX250-D1 (KX250) (1985)
KX250-D2 (KX250) (1986)
KX250-E1 (KX250) (1987)
KX250-F1 (KX250) (1988)
KX250-G1 (KX250) (1989)
KX250-H1 (KX250) (1990)
KX250-H2 (KX250) (1991)
KX500-A2 (KX500) (1984)
KX500-B1 (KX500) (1985)
KX500-B2 (KX500) (1986)
KX500-C1 (KX500) (1987)
KX500-D1 (KX500) (1988)
KX500-E1 (KX500) (1989)
KX500-E10 (KX500) (1998)
KX500-E11 (KX500) (1999)
KX500-E12 (KX500) (2000)
KX500-E13 (KX500) (2001)
KX500-E14 (KX500) (2002)
KX500-E15 (KX500) (2003)
KX500-E16 (KX500) (2004)
KX500-E2 (KX500) (1990)
KX500-E3 (KX500) (1991)
KX500-E4 (KX500) (1992)
KX500-E5 (KX500) (1993)
KX500-E6 (KX500) (1994)
KX500-E7 (KX500) (1995)
KX500-E8 (KX500) (1996)
KX500-E9 (KX500) (1997)
KX60-B1 (KX60) (1985)
KX60-B10 (KX60) (1994)
KX60-B11 (KX60) (1995)
KX60-B12 (KX60) (1996)
KX60-B13 (KX60) (1997)
KX60-B14 (KX60) (1998)
KX60-B15 (KX60) (1999)
KX60-B16 (KX60) (2000)
KX60-B17 (KX60) (2001)
KX60-B18 (KX60) (2002)
KX60-B19 (KX60) (2003)
KX60-B2 (KX60) (1986)
KX60-B3 (KX60) (1987)
KX60-B4 (KX60) (1988)
KX60-B6 (KX60) (1990)
KX60-B7 (KX60) (1991)
KX60-B8 (KX60) (1992)
KX60-B9 (KX60) (1993)
KX65-A1 (KX65) (2000)
KX65-A2 (KX65) (2001)
KX65-A3 (KX65) (2002)
KX65-A4 (KX65) (2003)
KX65-A5 (KX65) (2004)
KX65-A6 (KX65) (2005)
KX65A6F (KX65) (2006)
KX65A7F (KX65) (2007)
KX65A8F (KX65) (2008)
KX65A9F (KX65) (2009)
KX65AAF (KX65 (CANADA ONLY)) (2010)
KX80-E2 (KX80) (1984)
KX80-E3 (KX80) (1985)
KX80-G1 (KX80) (1986)
KX80-G2 (KX80) (1987)
KX80-J2 (Big Wheel) (1987)
KX80-L1 (KX80) (1988)
KX80-L2 (KX80) (1989)
KX80-L3 (KX80) (1990)
KX80-N1 (Big Wheel) (1988)
KX80-N2 (Big Wheel) (1989)
KX80-N3 (Big Wheel) (1990)
KX80-R1 (KX80) (1991)
KX80-R2 (KX80) (1992)
KX80-R3 (KX80) (1993)
KX80-R4 (KX80) (1994)
KX80-R5 (KX80) (1995)
KX80-R6 (KX80) (1996)
KX80-R7 (KX80) (1997)
KX80-T1 (Big Wheel) (1991)
KX80-T2 (Big Wheel) (1992)
KX80-T3 (Big Wheel) (1993)
KX80-T4 (Big Wheel) (1994)
KX80-W1 (KX80) (1998)
KX80-W2 (KX80) (1999)
KX80-W3 (KX80) (2000)
KX85-A1 (KX85) (2001)
KX85-A2 (KX85) (2002)
KX85-A3 (KX85) (2003)
KX85-A4 (KX85) (2004)
KX85-A5 (KX85) (2005)
KX85A6F (KX85) (2006)
KX85A7F (KX85) (2007)
KX85A8F (KX85) (2008)
KX85A9F (KX85) (2009)
KX85A9FA (KX85 Monster Energy) (2009)
KX85AAF (KX85) (2010)
KX85ABF (KX85) (2011)
KXT250-A1 (Tecate) (1984)
KXT250-A2 (Tecate) (1985)
KXT250-B1 (Tecate) (1986)
KXT250-B2 (Tecate) (1987)
So i'd imagine if you any of those bikes are listed...they would work
04/05 KX220 Hybrid all decked out
18 KTM 500 EXC-F Dual Sport/Sumo toy
24 KTM 300XC-W Cheater bike
