Will the E motor (89 to 94?) bolt in to the newer H frame?
Since it seems to be the favored motor in the ultimate KDX thread, why? Is it stronger down low than the 220 motor?
Thanks. I found one 89 motor locally and wonder if it's worth getting for a future swap into my 96 200.
Will the E engine bolt/fit into the H frame?
I would like to know that myself..... I'm thinking not.
An 'E':
An 'H':
If folks can put KDX engines in CR frames, I'm sure the E can fit into the H frame.
But...you did say 'bolt in'.
Look at the pipe routes. Looks to be a problem, don't it?
Re: '..favored. Why?'
Cylinders are not the same..meaning port differences. It's like wondering why a 106º centerline cam is different from a 110º cam in the same engine.
Ergonomics are considerably different. At least..any time I've ridden an E bike (only two of 'em), they feel completely strange to me. And, no, that isn't true of every 'different' bike I've ridden.
The KIPS on the E is a great big PITA. I wouldn't want to mess with it. It breaks a lot.
An 'H':
Yeah, the KIPS on the E series is just poor design on kawasaki's part. I have some ideas on how we could reduce the breakage there.
I do believe the E series engine would fit in the H series bike without major fitment issues. As Carvr mentions, pipe routing would likely be a pain. You'd probably have to cut and reweld the pipe, or use the header section from an E series pipe mated to the rest of an H series pipe. The angle that the pipe exits the cylinder from appears to be different.
Also, I have come to the conclusion that the H series engine or top end will not fit into the E series frame, because of the larger KIPS area in the forward part of the cylinder. It would hit the frame :(. You should not have this problem putting the E engine in the H frame though.
How about give it a shot and let us all know how it turns out!
I doubt the E motor would be much of an improvement over the H motor in a KDX frame. I've never ridden an E powered bike, so maybe I'm full of it.....Thanks. I found one 89 motor locally and wonder if it's worth getting for a future swap into my 96 200.
I bet the E motor would be great in any "modern" chassis, though. Then you would not have to worry about if it fits, 'cause it won't!
Put the E motor in a KX125 frame and you'd have something!
I'm still looking for a 175-250cc aircooled motor for a new project. Remember the IT175? Great motor!
I LOVED that motor!
My first ever Hybrid was a IT175 motor in a YZ125 frame.... That thing was a great woods bike!
Lots of folks prefer the E series engine. It's a damn good motor. I wouldn't see ditching an H series engine out of a bike just to replace with an E series motor though. I would however consider building up a bike with an E series engine and an H series frame if I had one bit or the other laying around to start with.
