Bike Performing Differently
Posted: 05:06 am Dec 04 2009
by Byte
Hi Guys.
My KDX220 is performing differently since i put the FRF exhaust spacer / Ring inside.
Oh - I've also topped up my transmission oil.
It feels like it is holding back and straining itself in first/second gear.
I am unable to get into third atm due to the very tight terrain on my property.
I don't whetehr this is due to the ring or something else...
Help?
Byte
Re: Bike Performing Differently
Posted: 08:36 am Dec 04 2009
by Tedh98
Remove the ring and see how it runs.
Posted: 08:37 am Dec 04 2009
by Byte
woudl i need to make any jettign chages or anything else to compensate fo rthe addition of the ring?
Posted: 09:19 am Dec 04 2009
by Byte
Assuming I did not have that ring in there, and still had this "pulling back" sensation, what owuld cause this?
Byte
Posted: 10:30 am Dec 04 2009
by fuzzy
Checked your spark plug for fouling?
Posted: 11:53 am Dec 04 2009
by Julien D
Byte wrote:Assuming I did not have that ring in there, and still had this "pulling back" sensation, what owuld cause this?
Byte
Let's not "assume" anything please. That gets nobody anywhere. Take the spacer out and test it again. Bet you can do it in less time than you have spent on this thread. I had one in my 200, hated it. Felt like it took WAY to much top end from the bike, and added only a little to the low end. Waste of money IMO, but I think I told you that already......
J.
Posted: 12:17 pm Dec 04 2009
by Indawoods
That is the general concensus. Jetting it correctly will take you further than anything else. Concentrate on that.
Posted: 03:27 pm Dec 04 2009
by Byte
thanks, i will look into all these options..
i guess to describe it better would be to say it is labouring.
would putting too much oil in the transmission cause this effect?
byte
Posted: 04:05 pm Dec 04 2009
by barryadam
Did your trans oil go into the exhaust?
Plugged up exhaust has those symptoms.
When's the last time you re-packed?
Check pipe AND muffler.
Posted: 04:08 pm Dec 04 2009
by Byte
Thanks. How do you tell if trans oil wen tinto exahust?
Repacked - unknown when it was done (if at all).
I will check pipe and muffler.
Byte
Posted: 04:39 pm Dec 04 2009
by Tedh98
Byte wrote:Thanks. How do you tell if trans oil wen tinto exahust?
Byte
Just remove the spacer!!
Shouldn't take more than 10-15 minutes at the most. No need to start chasing after other things.
Posted: 04:43 pm Dec 04 2009
by Julien D
If you put too much oil into the tranny, yes, it can cause some extra drag. Probably not enough to notice unless you filled it up to the top of the fill hole or something silly like that...
Posted: 06:37 pm Dec 04 2009
by Green Hornet
I find it hard to believe the Torque Spacer would cause this.
Posted: 05:22 pm Dec 05 2009
by Byte
Perhaps this torque spacer is doing what it intended - creating more low end torque and it is this increased torque I am noticing that is different...????
Byte
Posted: 07:38 am Dec 06 2009
by Julien D
When you eliminate the impossible, whatever remains, however improbable, must be the answer.
Take the 15 minutes to pull the spacer out and give it another run. Why are you so reluctant to do this???
