Assembly lube on new piston?
jackpiner57
Post by jackpiner57 »
I found some Bel-Ray assembly lube and wanted to know where to put it. Is this the right stuff to use? Should I coat the piston and rings and then wipe off? Use on small end bearing too? Coat cylinder wall too?
2002 KDX200
2005 KX85
2005 DL650K5 V-Strom
NETRA
AMA
Montshire Trail Riders
Vermont Motocross Association
I got stopped for speeding and the cop asks me "Don't you know the speed limit is 55 miles per hour?" So I said "yeah but I wasn't gonna be out that long."
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Just use your 2-stroke oil...coat all the parts... don't wipe off. You'll be good to go...
jackpiner57
Sounds good to me, thanks!
2002 KDX200
2005 KX85
NETRA
AMA
Yep, just use 2-stroke oil.
I think your idea to coat, then wipe off is good. I just read that this morning in a motorcycle general repair book. I guess I would rater have glazed over doughnuts instead of rings / piston / cylinder, etc.
canyncarvr
Post by canyncarvr »
Used to be common practice was to DUNK the whole mess (piston/rings) in a pot-o-oil.
Probably more likely to cause a problem wiping it than leaving it alone. Ring edges/ends are real sharp.
I usually pour on a 'glob', squeegie it around with my finger, giving the rings a few back-n-forth wiggles to make sure the lands are coated.
A maybe too late BTW... if you got a back ring for the second ring (the spring metal just-had-a-permanent-looking-thing?), leave it out. What it does best is get stuck.
You might want to slowly kick it over a few times before giving it an official kick.
jackpiner57
CC, Can you explain the BTW a little more clearly? Do you mean don't put on the lower ring?
2002 KDX200
2005 KX85
NETRA
AMA
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
He's talking about a backing ring.... It looks corrogated that fit below the bottom ring. Basically, if it comes with 3 rings... ask!
Most manufacturer's don't use them anymore... My Pro-X didn't and Weisco only has one ring I think.
You can look on the buykawasaki.com parts diagram to see exactly what he is referring to.
When I helped wsjkawasaki put in a new Wiseco piston in his 220, it came with two rings and no backing ring(s).
jackpiner57
Thanks Inda, EG is sending me a Wiseco, so I won't worry about that.
Thanks Jason I'll check that out.
2002 KDX200
2005 KX85
NETRA
AMA
No problem. On the Wiseco instructons, I think it said to run the lettered side of the rings pointing up.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I've never used a Wiseco piston...was only going by pics I've seen. Good info Jason.
motorider200
Post by motorider200 »
Indawoods wrote:Weisco only has one ring I think.
Weisco's have two rings. I have a pic of a toasted one in my gallery. :shock:
97 KDX200(225)- mine
01 KDX220- brothers
97 XR400- dads
IdahoCharley
Post by IdahoCharley »
FWIW - letter side "up" on all rings installations no matter what brand of piston.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
jackpiner57
Thanks guys for all the good info.
2002 KDX200
2005 KX85
NETRA
AMA
