KIPS "Ball Bearing"
KIPS "Ball Bearing"
Postby raisedinal » 10:10 pm Oct 31 2009
Hey ya'll its me again. Replacing the piston and was dissassembling the KIPS assembly for cleaning and while pulling the "Main Shaft" of the Valve assembly out the Ball bearing fell on the bench from the other side.
I see from Cyclopedia it says to remove it:
and then in the other chapter it doesn't mention it again.
I know I have to put it back but I didn't see where it fell from or where to put it back to? Can someone clear this up for me?
Does it just ride behind the plate with teeth which is held on by the nut?
Thanks in advance Ya'll!
JT
raisedinal
Has thanked: 1 time
Been thanked: 0 time
Postby Indawoods » 10:56 pm Oct 31 2009
See that bolt below? There is a spring and your ball bearing that the bolt hold in there....
Does that help?
"People ate cows a thousand years ago for the same reason we eat them now. Cause they are easy to catch.We're not savages,we're´╗┐ just lazy. A cheetah could taste like chocolate heroin. But will never know. Those bastards are fast!!! "
Has thanked: 0 time
Been thanked: 19 times
Postby raisedinal » 01:38 pm Nov 01 2009
uh....oh a spring? I saw the ball fall out...not the spring? Dang...
2002 KDX220, Wiseco piston, RB Head and Carb, FMF Rev, 0.41 fork springs in stock forks.
raisedinal
Has thanked: 1 time
Postby DirtBikeDad » 01:41 pm Nov 01 2009
raisedinal wrote:uh....oh a spring? I saw the ball fall out...not the spring? Dang...
If you haven't taken that bottom bolt out, chances are the spring is still in there. IIRC, the spring is underneath the ball bearing. Pull the bolt to verify.
DirtBikeDad
Jeremiah 29:11-13
"That's not flying, it's falling............with Style"
'99 Honda CR250R (Keith)
'99 Honda CR250R (Wilson 15)
'00 Yamaha YFM350 Warrior (Travis 13)
'90 Kawasaki 220 Bayou (Farm Toy)
DirtBikeDad
Has thanked: 0 time
Postby raisedinal » 01:48 pm Nov 01 2009
Just looked at it...I see now the spring goes in the hole and the ball bearing on top of it to act as a detent/cam to the cog! I didnt' see that spring...it may be a gonner! I'll drag a magnate around with hopes that it'll find it since it probably bounced off. Has anyone ever ordered this spring...alone?
raisedinal
Has thanked: 1 time
Postby raisedinal » 02:51 pm Nov 01 2009
DirtBikeDad wrote:>|<>QBB<
Thanks! it was still in there! it was in a bind and compressed inside it but I have it! Thanks! All parts accounted for now! I feel I need to smooth the inside of that bolt out so it doesn't bind in there or it won't give the detent thats needed? I'll start reassembling tonight then I'll just wait till the Carb and Head come back from RB!
raisedinal
Has thanked: 1 time
Postby gregp » 04:29 pm Nov 03 2009
I prefer to leave the ball and spring out. The motor is much more lively. The low end is still there, but the transition to the mid/top happens much more quickly. This "mod" may not suit you if you do not ride aggressively all the time.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
gregp
Has thanked: 0 time
Return to KDX General Q&A
Who is online
Users browsing this forum: No registered users and 14 guests
cron
