Shift shaft seal
JoKDX220r
Shift shaft seal
Post by JoKDX220r »
Hi all,
Some oil leaking from my shift shaft, I wonder if the seal can be removed from the outside like the output shaft seal ?
Thank you!
The shift shaft seal is placed from the outside.
Seal PN is 92051-005.
Check the 'Crankcase' diagram on kawasaki.com, or page 7-2 (in my manual anyway) of the service manual.
The shift shaft comes out from the RH side. It's under the clutch. If the shift shaft seal is leaking, there might be some wear on the shaft that's helping that happen.
I've not replaced a shift shaft seal. Verification by someone that has done it would be good.
Shift shaft information is in the clutch section of the manual.
