13/49 gearing
jbowens2401
13/49 gearing
Post by jbowens2401 »
Does anyone know if I can run 13/49 gearing with the stock chain on a 2005 KDX 220? I think 12/47 will be a bit low for me.
Thanks,
John
Proly take a 110....
jbowens2401
Thanks, that's what I was afraid of.
jaydollar
Post by jaydollar »
if the stock chain is streched,it will work,a.k.a. snails are on the big part of the cam...past 7 or 8.try this For a good chain.EBAY item #170127251875.thay also have 110 link if you look in their store.i have been running one for years with no problems.also jt steel sprockets on ebay for $25.00 from lytle racing.J$.
1999 kdx 220
rb carb, rb head pump gas mod. 607 reeds, airbox lid drilled
fmf torque pipe
fmf turbine core Q
trail tech endurance computer
13/49 gear
jbowens2401
jaydollar,
Thanks for the feedback. I see you are running 13/49 gearing...how do you like it, and what type of riding do you do?
Thanks,
John
jaydollar
Post by jaydollar »
no prob jb.mostly tight single track with a lot of ups and downs.stock gearing 2nd and 3rd seemed a bit to high,the 49 made it perfect for me with no real noticeable loss in the top end for the occasional fire road,J$.
1999 kdx 220
fmf torque pipe
fmf turbine core Q
13/49 gear
jbowens2401
That's the same type of riding I do here in middle Tennessee, and I think the stock gearing is a bit too tall. I've got a 49t rear coming...hope my chain is long enough. If not, I've got spare links and master links to make it work.
Thanks again,
John
tbirdsp
Post by tbirdsp »
I'm running 13/50 and needed a 110 (stock is 108).
Everything is new and my adjusters are on 5.
Mike S.
'98 KDX200
'07 KLX250S
'06 KLR650
'93 ST1100
jbowens2401
update
I installed the 49t sprocket last weekend, and really like the combo (13/49). 1st gear isn't so low that it's unusable, and the gearing ratio seems to be much better. I think 12/47 would have been a little low. Also, I had to add two links to my chain (108 to 110), and my snails are on 7.
fromotop
Post by fromotop »
I am now running 14/52 up from 13/52. Much better for the desert riding i do in New Mexico. 108 chain but I am thinking a 110 would be better in the long run.
That must be one stretched out chain! :shock:
fromotop
Post by fromotop »
It is, although it still looks good. The bike is new to me after selling my 94XR250 and buying this 04 for the same 1700.00. This bike is much better for my riding style.
