All fixed up now what?
Posted: 11:08 pm Aug 28 2009
by 2FAST
Ok I now have my power core silencer and fmf wood's pipe new dunlop D 952 on back and front and lot's of other odd's and end's!!! Now onto my question ive been thinking real hard on removing the snorkle deal I dont do much water riding soooo should I ditch it any gain's what so ever? some one give me a pointer or 2.
Posted: 01:50 am Aug 29 2009
by Jonooffler
Hi my bike is stock at the moment and I have removed my snorkel the only change I have found is that it is noisy.I looked around on the net and there are a lot about removing it and finding loads more power i never found it.
Try it and see don't try to cut down the lid there are lot of owners out there looking for new lids to replace the ones that they cut up and found it gave problems.
Jono
Posted: 06:28 am Aug 29 2009
by Julien D
Removing the snorkel and/or lid will give you some more airflow. You will need to re-jet afterwards to see any real performance gain, unless you're running rich to begin with.
Posted: 10:12 pm Aug 31 2009
by 2FAST
Thank's for the input guy's I think I will try just removing the snorkle and if it give me problem's just put it back in..
Posted: 10:41 pm Aug 31 2009
by bezoar
I did this also in steps. I first removed the snorkel and rode it 10 or 15 times, got it jetted fairly good and was happy with things.
Last week I decided to cut off the back of the lid. Noticed two things......
First, it does run leaner which supports the theory that the lid is restrictive.
Second, I noticed that there is not one very dirty spot on the filter. I suspect that the smaller opening for the snorkel causes a fast stream of air that hits the filter in one spot. When you open the lid, the incoming air does not favor one spot on the filter.
