Another fuel question. Has anyone experimented with a lead additive with there KDX?
Since the lead additive is a lube in the fuel was wondering if it would minimize wear and tear a bit and be a overall help
Lead additive
TEL was used primarily as an octane booster.
If that's what you're after, use an aromatic hydrocarbon.. like toulene.
My answer to your question, though, is, 'No.'
The lead additive in gasoline was to help the valve and valve seat interface live longer on 4 cycle engines.
When lead additives were removed from gasoline the automobile manufactures when to an insert valve seat to compensate for the lack of lead. Prior to this valve seats were machined into the base material which made up the head.
The lead additive was always an determent to a 2 cycle engine IMO due to the easier fouling of spark plugs.
Just trying to keep some facts straight in the old brain.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
- MXOldtimer
Uhhhhhhhhhhhhhuuuuuummmmmmmmm! I got to disagree.
Lead in fuel ups the octane rating, it also has the ability to resist detonation and/or pre-ignition with "high" compression 2 smoke engines.
Lead is pretty much needed to build a "high compression" 2 smoke engine to run with the bigger thumpers.
Remember the hub-bub at the end of the 2 smoke vs 4 stroke battles and the fuel penalties against Reed and a few others for running lead in their 2 smoke fuel? It was a FIM rule adopted by the pantie waisted AMA that helped destroy the smokers even more.
But, the penalty was dropped against RC for have'n lead in his thumper fuel.
Lead is a benefit in 2 stroke "performance" but for us weekend warriors...........99.9% don't know how to jet a bike so running lead will do us about as much good as wearing RC boots and expecting to win a race..
04 KX-250 Hey.....at least it's green and smokes.
06 KDX-200 for off road play. Gone but not forgotten
07 KX-250F SOLD! I thump no more.
- fuzzy
Very true old timer!!! but still wouldn't add lead additve to pump gas...Would go w/ tolulene as mentioned. Big difference between pump gas laced with lead and VP C12/14/16 which are great 2T racing fuels that happen to be leaded.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
