93 kdx 250
r1inoz
93 kdx 250
Post by r1inoz »
hey all
i recently purchased a 93 kdx 250.
i got it running(very poorly)and the engine oil turned to a lovely shade of whitish pink from red.
i assume it is a head gasket but i inspected it and found it not damaged(its a thin metal shim )could it be a cylinder gasket or water pump seal instead
any help would be greatly appreciated also if the head was not torqued down correct would that cause water in the oil
ty
andy in oz
More than likely the waterpump seal... change the oil a few times and it may clear up if it has been sitting quite a while...
Any oil in the water?
r1inoz
Post by r1inoz »
not sure because it had no water left in the radiators when i drained the oil
it was sitting for a while i believe
My vote is for water pump seal as well. Pretty common failure on these bikes, and easily remedied.
r1inoz
Post by r1inoz »
ok went to the bike shop and ordered the water pump seal,i explained to the guy what parts came out and what order(should have taken the whole side case in not just the shaft with the bearings etc)
he said i wwas missing a weight governer another piece that goes on before the impela.
is he yanking my chain because it didnt look like it had been taken apart before!
any pics u guys have of a disassembled water pump would help immensly
also there is a hole in the bottom of the case under the water pump,im pretty sure the manual called it a weep hole but not 100% sure.
sorry for all the q's have not got my hands on a manual yet
ty
andy in oz
If you go to bike bandit, and look up the side covers schematic, you can see all the bits and pieces that go in there.
r1inoz
Post by r1inoz »
i tried bike bandit,ron ayers etc but as it turns out i have the kdx 250 f sr model the australian model
does anyone know where i could find the schematic for this model
i have searched everywhere and scame up with nada.
ty
andy :supz:
fuzzy
Post by fuzzy »
I'd bet the SR is no different (in this area).
r1inoz
Post by r1inoz »
it is different in the impela section and im getting told the mechanical seal is pushed in from the inside to to the out side but i cannot see it going in that way will try to post some pics soon
