I thing i have a clutch problem :S
hello, I wonder if this is normal when my bike is stop(engine not running) and put the first gear, I press the clutch and try to move the bike. The rear wheel is blocked as if I did not touch the clutch. Normaly on a car if you touch the clutch you can move the car, but on my bike if i'm in first or second ... the bike don't move even if i touch the clutch.
I want to precise that when i run with the bike , the gear are changing properly and all gos well
- Colorado Mike
That's a pretty common problem and is usually caused by the clutch basket fingers getting grooves worn in them. You can disassemble it and file them smooth again. supposedly switching to a Hinson clutch will improve things because the surface is harder. I never tried one though.
Mike
'04 KDX220
'04 KDX220
It happens with a brandy-new basket, too. Hinson, even (I have one). The notchy basket will give you trouble shifting when the engine is running.
Which is to say...it's normal for the KDX. Bikes that activate the clutch from the INside don't usually have that problem. The KDX activates from the OUTside.
That's why the KDX is harder to start in-gear than some other bikes, too.
If you have to move it in-dear, engine off, clutch pulled....rock it back and forth a time or two 'til you feel the plates break loose. It will still be hard to push around but the back tire won't be skidding along anyway.
...unless you're on something slippery..much...gravel over hardpan..something like that.
There are clutch anomalies that can make the stickage worse than it otherwise might be...but it's always going to be there to some extent.
- RBD
- jaydollar
A stalled bike, in gear, driven by the rear wheel...don't shift fer diddle. Put your not running bike in gear, pull the clutch, go downhill, just try to shift into neutral.
Point is..shifting into neutral is not always an option.
Point #2 is, the answer to keyfort's question is...'It's normal.'
For a KDX anyway.
For a KDX anyway.
- Colorado Mike
Hinson clutch baskets are history. No where to be found..
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Which is why I bought one before they went away.Green Hornet wrote:Hinson clutch baskets are history. No where to be found..
No one said you could get 'em anymore..just that they work better.
Work better than what?
Better than what was in the bike to start with..meaning the OEM basket.
