Differences in engines over the years
Tedh98
Post by Tedh98 »
I'm wanting to do a hybrid with a kdx 200 motor. What years were the engines the same? Like '88 - '95 and '96 +.
I've found a cheap '92, but I'm curious how outdated that engine is. I've got an '86 kx 250 that I can't find parts for and don't want to run into a similar situation with a '92 engine.
Thanks for the help.
89-94 are the same... 95 and up are the same on the 200 and 97 and up are the same on the 220.
I personally like the 89-94 motor better than the 95 and up but they like to chew up KIPS drum gears...
Tedh98
Post by Tedh98 »
Thanks for the quick reply. One last question, I think. When they changed the 200 in '95, did the entire engine change (from the cases to the cylinder & head) or where the changes limited to certain aspects of the engine?
I guess what I'm trying to get at is if I set-up the frame for a '92, would I be able to bolt in a '95+ a couple of years from now without having to make changes?
The motor along with the frame was a complete redesign... sorry.
mhosfelt
Post by mhosfelt »
I just bought a 92 that has never had the motor apart. It runs perfect. starts with 1 or 2 kicks even after it was completely under water. I ride mostly in tight woods and I am amazed how proficient this 17 year old motorcycle is at this task.
Tedh98
Post by Tedh98 »
I bought this '92 for $100, we'll see if I can fit it in a yz 125 frame. If I can make it fit, I hope I have several more years of being able to get parts for the engine before everything dries up.
