KX Full Front End for KDX220 97
Byte
Post by Byte »
I read that the KX front end is a desired for the KDX.
What is involved to install a full KX front end (forks, t-clamps, wheel & hub)?
Part numbers, procedure, etc.
Re-valving with Race Tech Gold Valves enduro
Byte
http://kdxrider.net/forums/viewtopic.php?t=146
There is a whole forum dedicated to frontend swaps....
Byte
Post by Byte »
Many thanks.
Which year KX front end is best recommended for the KDX 220 97 year?
Where can I locate part numbers?
WHy is KX totuted a sthe ebst front end mod you can do?
Byte
Because all you need to do is swap the stem and it's bolt on from there....
Anything 96 and up is desired....
Byte
Post by Byte »
but why kx - ?
why do the mod in first place?
how does kdx differ to kx suspension?
byte
Dude... look around the site... Google images of KX's and then KDX's... Read the Fork Conversion Forum... look around a bit.
skipro3
Post by skipro3 »
this is just getting to be too funny!
AtomicKDX
Post by AtomicKDX »
Yes, always listen to the moderator...it's like listening to Yoda's advice.
Here's my bike with KX forks:
Byte
Post by Byte »
Atomic - nice bike.
what year is your kdx 220?
what year forks KX did you install? (part numbers)?
BYte
Part numbers are kind of a moot point. It would cost you a couple thosand dollars if you bought this stuff new... go by year.
Byte
Post by Byte »
Thansk Inda.
