I'm done with my case split/reassembly but now I wonder if it's normal to have a small play in the output shaft ?
Just before I reinstall the sproket I noticed that I can push the shaft into the case, just enough to make it difficult to install the clip that hold the sproket in place..
1. the case had no oil in it
2. the O-rings and collar was there
3. There's no more play with the sproket and clip in place...
I try it and with motor off, everything worked fine.skipro3 wrote:Also, does your bike shift into the taller gears when motor is off? Put the bike on a stand and rotate the rear tire while shifting tough the gears. Should shift fairly easy. Then start the bike and try it again while on the stand. Let me know what happens.
Thanks!
