Well I got my flywheel off, finally. I used an oil filter wrench. It held it perfectly, but when the nut came free I ripped a chunk of flesh off my pinky finger about the size of a dime! OUCH!!
A little rust inside the flywheel. Should clean up though.
Then I noticed something I was not suspecting. The stator in the bike was not the same as the extra one I have. I bought my Dual Sport Kit used from a guy I know. He ahd it installed on his 2005 KDX 220, but when he sold it he took it off and I bought it. With the kit was a stator. He thought it was the original one out of his bike as he had bought one from Fredette for 65-75 Watts. He thought he had installed it and this was the one he took out. Well this looks to me like the Fredette one.
Am I mistaken, but I thought the thicker the wire the more power you generate. The one in my hand has wire at least twice as thick as the one on my bike. I had bought 17AWG wire to rewind one of these and that looks like what is already on the one that is in my hand. Any thoughts?
What Stator is this?
2002 KDX 200
no thoughts other than it looks like you're right about the winding size:
http://www.advrider.com/forums/showthread.php?t=189734
bigger wires mean less turns, less output at low rpm, more output at high rpm. i though carver was all over this type of thing
Darn tootin' I'm ALL over it!
What was the question? WAS there a question?
What makes 'power' is two rather different things, one of 'em current, one of 'em voltage. The rotating magnets (and thus the magnetic fields surrounding them) glued onto the flywheel generate electricity when that field 'cuts' (moves across) the coil.
The more 'cuts', the more voltage.
The thicker the wire, the greater the ability to carry the current to push that voltage.
There is almost always a 'loss point' (my phrase) to one or the other...or both. You can wrap the plates with a whole lotta fine wire, get a high voltage (like the sparky coil), but you won't have the current needed to accomplish much power-wise 'cuz you won't have enough current. You can use real thick wire that will carry a lot of current...but then you won't be able to wrap enough layers around the plates to generate any voltage.
You can use more plates, real thick wire, AND wrap it alot of times...but where is it going to fit? An how much power is going to be generated when that puny rotor flies past your coil that's the size of a small car?
The top coil looks like an OEM unit to me. The bottom looks like an Electrex coil, which is what Fredette (and MSR, and others I suppose) sold.
Lots of things make a lot of small differences...add them up to hopefully get something that works. Canadian Dave used to simply RE-wrap coils with the same wire. He had come to the conclusion that a tighter/closer wrap of the same wire improved the coil's output.
I never tried that. Don't know how effective it was.
To test either/both of them, you will need some sort of adjustable load...like a carbon pile setup or a wire-wound/ceramic resistor that has something akin to an adjustable center-tap. Hook up a couple of meters...see how much current they put out before the voltage drops below a useable level. You can guage that 'useable level' by putting a lamp in the circuit...watch for it to dim while you add load to the coil output.
Unlikely you want to bother with any of that.....
Depending on the quality of the construction, wire, and wiring, either of the coils pictured could be better than the other one. Chances are the bottom one will put out more P=IxE... Power in watts = current in amperes multiplied by voltage...in volts!.
...or giga/mega/kilo/milli/micro-s thereof.
You're not dealing with a 'power to spare!' issue.
