STRIPPED TANK INSERT
MY KDX 220 R
Post by MY KDX 220 R »
I am really feeling frustrated, doing general maint' and when replacing the left hand side radiator shroud, managed to strip the brass insert in the fuel tank! It has always been a problem to get the bolt lined up correctly and I now have an insert that is spinning weather I am turning clock / anti-clock. I have tried to wedge it and then loosen, but no joy!
Please if there are any suggestions out there please let me know -
it is a '05 220.
Thanks in advance. :evil:
KEEP IT REAL!!
clutchcover
Post by clutchcover »
You know, every one I've ever had do that, or other people I've seen it happen to has ended up being a lost cause. Hopefully yours won't be. We tried epoxy, super glue, melting the plastic back to it, digging it out, and everything else imaginable. Never had a successful attempt. All I can say is give it the good college try, and hopefully someone else know a trick or two. Good luck....
97 Kdx200
Summuda goodies.... But not quite enough.
quailchaser
Post by quailchaser »
I'm surprised that a good epoxy didn't work. :? That would have been my suggestion. As far as the shrouds not fitting, I elongated the holes in the shrouds so that there was no longer a fitment problem.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
jackpiner57
Post by jackpiner57 »
Anyone know what kind of plastic it is? Is there a PP for Polypropylene, or PO for Polyolefin, etc. on it? Once you know what plastic it is, take the tank to an auto body shop and they might have the correct adhesive for it. 3M might have one for that specific plastic too.
2002 KDX200
2005 KX85
2005 DL650K5 V-Strom
NETRA
AMA
Montshire Trail Riders
Vermont Motocross Association
I got stopped for speeding and the cop asks me "Don't you know the speed limit is 55 miles per hour?" So I said "yeah but I wasn't gonna be out that long."
skipro3
Post by skipro3 »
Although I've never tried it, you might try P-Tex. P-Tex is a plastic used to repair the base on a ski. It comes in stick form, like a pencil. You light it on fire at one end, then hold it like a candle you are dripping wax from. Drip the P-Tex into the slop of the junction between the insert and the tank. After it hardens, chill it down with ice so it is hard when you try to back the bolt out of the insert. Since you are managing an open flame around a gas tank, remove the tank and fill with water while you do this to prevent explosion.
Jerry
KDXer
Post by KDXer »
I've done it on two of them on my tank. I used a blunt drill to drill the bolt head which produced enough heat to melt the surrounding plastic to slide it out. Then simply pull the insert straight out. Clean out the hole and of course the bolt gets destroyed or damaged but you should be able to seperate the bolt and insert now. I used a 5 miniute aryldite? (epoxy) to glue them back in and they haven't moved after LOTS of shroud removals. Hope it helps some. This was the only way I found to get these buggers out.
OH BTW a torque wrench is your friend !! :lol:
MY KDX 220 R
Thanks for all the good info, will give it a go. To any one that has not done this yet heed the tip to slot the holes in the shroud, this was not a case of over tourque, purely an alighnment problem and the brass inserts do not seem to enjoy the cross-threading.
Thanks again and will post the results as soon as I have it figured.
KEEP IT REAL!!
Hi. Do all of the mounting areas on the 95 and up shrouds go into brass inserts or only some? On my '94, there are some of each. I always do the brass ones first.
Mark W
Plastic
Post by Mark W »
If you can find out the type of plastic, I can find you an adhesive that will work. 3M has many adhesives that work on a variety of low surface energy plastics.
Mark
MY KDX 220 R
The two that attatch to the gas tank are brass and then there are two - one on each radiator that attatch to a clip - total of three bolts per shroud.
Low surface energy plastics, that went completely over my head, but I am sure that if I can find the correct type of adhesive to match the plastic I will have solved half the problem.
The other half is trying to get the bolt out - will try the suggestion of drilling it out and hopefully not having too big a hole left in the tank as a new one is approx' $ 263.00 and I could spend that much more comfortably on a FMF system.
:neutral:
KEEP IT REAL!!
Thanks for the bolt information. Good luck with your shroud.
Mark W
Post by Mark W »
Low surface energy plastics would be described as HDPE (high density polyethlyene) PE, Nylon, PP (polypropylene) and to the extreme teflon. Most plastiics, such as the gas tank would be classified as low surface energy meaning that not many things stick to it. Most of these plastics require some type of priming to force an adhesive to stick (liquid primers, flame treating, scuffing etc...). 3M has many different types of adhesives that require no priming and will cause a substrate failure verses a bond failure when the adhesive lets go.
I'll look for the plastic but I'm away form the bike for a few days.
Mark
KDXer
Post by KDXer »
While drilling it try to produce heat rather than drill the bolt head off. Apply constant pressure by pulling outwards on the bolt or shroud and when its hot enough it will slide straight out. As long as you keep pulling on it while drilling it will ensure you don't melt it too much... Just my experiences.. Hope it helps some.... Trev
kingsxjt
Post by kingsxjt »
http://www.urethanesupply.com I save this in my favs in case I ever needed it. Maybe you can find something you can use here!
MY KDX 220 R
If you can't find it here then I suppose it doesen't exist.
Good info' see why you have it book marked.
Thank you this will really help. :grin:
KEEP IT REAL!!
canyncarvr
Post by canyncarvr »
Use anti-seize on reassy.
A thread locker will work, too. Anything to keep the dissimilar metal reaction from happening.
MY KDX 220 R
A quick note :
The plastic fuel tank is made of polyethylene mark: >PE<
Aparently this can be repaired using a plastic welder and PE rods - a thermal repair.
I am going to H-Depo to see if there are any chemical products that would be compatible in repairing the tank.
Later.
KEEP IT REAL!!
m0rie
Post by m0rie »
Keep us posted on the tank repair. If you find something that works it would be handy for those of us with older tanks that Ma-Kawi won't swap on warranty.
-Maurice
1989 KDX 200
2007 TTR-50E
MY KDX 220 R
WILCO
KEEP IT REAL!!
MY KDX 220 R
Managed to remove the insert last night.
Much like trying to pull a tooth, alot of force was needed to pull it out in relation to how little was needed to have the insert strip in the plastic.
Once the insert was removed, using a DREMEL tool to clear away most of the rough edges etc. used the JBWeld Kwik. to re- insert the insert??
The JB seems to hold but did not hold on the flat surfaces too well.
This said I was still able to sand the JB and have a fairly good finish.
Should this not be a pemanent solution I will post again. :cool:
KEEP IT REAL!!
