To his defense...he DID say, '..
unless you're heating the part they're going into..'
But...
If freezing makes no difference UNLESS you heat....the word 'unless' means one is dependent in some way on the other. 'You can't go UNLESS you clean your room!' So, there is obviously some kind'a magical connection between the freezing of the one and the heating of the other.
The things to be learnt from the frozen north. Hey! They're gettin' rid of them dang polar bears, aren't they?
Is a frozen polar bear smaller than an UNfrozen polar bear?
Or...maybe not UNLESS you heat up the ice floe it's floating on.
It follows, therefore, that Canuck's are therefore responsible for Global Warming!!!
THEREFORE I say!!!
So...how about freezing ONLY,
then seeing if they fit different from room temp.
Yeah...we could just believe what he says...but where's the fun in THAT? Let alone the
DRAMA!!
It occurs to me: If freezing makes no difference UNLESS you heat..
Then NOT freezing DOES make a difference if you DO NOT heat.
Sheesh...it's as plain as day!!
With FREE SHIPPING even!!
