I have just brought my first KDX200 a couple of days ago, form the serial number KDX200G-015744 I think it is a 1993 model.
I have read that the stock expansion chamber has an acoustic lining which when removed will ‘really wakes the KDX up’.
After chopping the pipe as per the instructions I found only a small (may be a 1/5) of the internal area had a metal gauze.
It had not been cut open before around the circumference, but may have been opened along the original welds.
Do I really have a 1993 model bike?
If so does a 1995 on and onwards expansion chamber fit perfectly on a 1993 model?
Has someone already done this mod or have I got the wrong pipe?
All comments gratefully received.
Do I have a 1989 to 1994 exhaust?
If you have a pic, it can be identified immediately.
I did this mod to the pipe on my 89. The internal packing only runs between the two rings of spot welds that you can see on the outside of the pipe. It's not very long, just through the fattest part of the pipe. Removing all that junk made a HUGE difference. Enough so that I feel I'm able to hold off on putting an aftermarket pipe on. I'll run this one until I manage to destry it.
J.
J.
It's a 93-94
