fork re allignment?
alistair
fork re allignment?
Post by alistair »
after a 3rd/4th gear crash i think my forks are twisted in the clamps.I did a search but i didnt know the right terms to use i guess, as i couldnt find what i needed.so if someone could tell me how to do it,or show me the links that i couldnt find that would be much appreciatd.
my bike has standard 2006 H series conventional(RSU) forks.
thanks
06 kdx 200 - mine
06 kdx 200 - dads
We used to put the wheel up against a tree and turn in the opposite way... :lol:
Proper way is to loosen the clamps up enough to straighten them and then torque them back correctly according to the manual.
alistair
Post by alistair »
i tried the opposite tweaking method still rides twisted,are you meant to undo the top and bottom clamps?as i tried just the tops,still seams twisted
06 kdx 200 - mine
06 kdx 200 - dads
skythrasher
Post by skythrasher »
Sometimes it is only the bar mounts that are twisted. The cupped washers under the nuts and pins will bend holding them in this tweaked position. Just something you may check. I installed FRP's top barmount and this problem doesn't happen anymore.
My Gallery
2001 KDX200
1987 KDX200
2002 CR250R
2016 KTM 350XCF-W Six Days
Mr. Wibbens
Post by Mr. Wibbens »
Thought i read somewhere's to loosen the pinch bolts on your forks, upper and lower, 'til they just barely stay in place
Then spin the front tire and lock the front brake a couple times
Tried this the other day on my Vstrom, it really seemed to help
KDXPhoneDude
Post by KDXPhoneDude »
I remember Inda giving that advice.
It's somewhere on this board.
alistair
Post by alistair »
thanks guys i will give that a shot today,im hoping my handle bars are still straight,its a bit hard to tell....
06 kdx 200 - mine
06 kdx 200 - dads
Take note of what Skythrasher said. The OEM iso-mounts with the OEM top clamp setup WILL tweak easily. You would swear something's bent, but it's not.
Take the isolaters out, put them back in....maybe swap'm around just 'cuz. That will sufficiently 'reset' them.
Doesn't mean something isn't skewed on your bike.
...and Wibby's post will take care of that, if it's a forktube alignment problem.
Mr. Wibbens
After my little chance encounter with a deer a couple weeks back my Vstrom felt f'd up going into slow speed left turns
Felt like my forks were tweeked
I tried Inda's little trick over the weekend and the forks feel fine now :supz:
alistair
Post by alistair »
trhanks everyone,wibby's litle trick helped.its still a litle skewd but i think thts is now my handle bars.i believe the mounts are straight,the isolateing cones things have been replaced with some sort of suspention bushing materail that dad machined up.
thanks i got it to a pont here i can live with it i think,might go for a ride sat/or sun and find out f i can adjust to it
06 kdx 200 - mine
06 kdx 200 - dads
It's less the iso-cones than it is the OEM handlebar clamp setup....'cuz the same cones with a better clamp don't have that problem.
alistair
Post by alistair »
canyncarvr wrote:It's less the iso-cones than it is the OEM handlebar clamp setup....'cuz the same cones with a better clamp don't have that problem.
alright I will keep that in mind and i might have to go have a play around with them.although if i sit on the bike and eyeball it the clamps look to be in the same position,but the crossbar on the hangers are in a different spot relative to the clamps.
06 kdx 200 - mine
06 kdx 200 - dads
It's been awhile since I had to mess with them..but as I recall what you describe is exactly what appears to be when the things need to be reset.
Of course...it's ALSO exactly what appears to be when sumthin's just plain BENT!
Isn't THAT helpful................ :roll:
alistair
Post by alistair »
haha,i guess ill pull it apart and reset every thing.cheers
06 kdx 200 - mine
06 kdx 200 - dads
