Okay so I feel like complete moron. I recently cleaned my carb... recently purchased the bike and the PO left it sitting with gas for awhile, so just making sure.
Here is my question, I tried to remove the needle to check and see which one it was, and what clip position it is in... but it won't come out. I have the Kawasaki manual and they don't say anything about having to unscrew it or anything, but am I crazy or is my needle just stuck in there, or do you have to do something that I am obviously missing to get it out?
I removed the top cap and throttle cable, but cannot get the needle out of the slide.
So there is my dilemma.
The bike runs fine, but I just wanted to make sure I can get it out in the future.
Thanks for any advice.
Brian y
Dumb carb question
- Colorado Mike
It is indeed a 6mm, but be very careful with this nut. The metal is a special alloy of phuckmesium and decomposed toilet paper. Coupled with the very fine threads and limited access, this combines to give you fits if someone twisted it in with any authority at all.
This isn't to say you should avoid messing with it, just use the proper 6mm six point socket, and do use anti-seize on the threads when you gently put it back in.
- Mr. Wibbens
oops I was backasswards
Thanks a ton. Now I know what I need to go track down.
Brian Y
Brian Y
Colorado Mike wrote:It is indeed a 6mm, but be very careful with this nut. The metal is a special alloy of phuckmesium and decomposed toilet paper. Coupled with the very fine threads and limited access, this combines to give you fits if someone twisted it in with any authority at all.
