Hi Guys,
I have searched on here for details of the tool required to hold the damper rod whilst the outer bolt is undone, I seem only to be able to find details of the tool for later forks. I have conventional forks fitted to a 1990 kdx 2oo, is the tool the same or different?
Can someone tell me if the end of the tool is male to fit into female on the end of the rod or is the end of the tool female to screw over (so to speak!) a male thread on the end of the rod? It seems like it is a nut welded onto a tube, anyone know the nut size and the max tube diameter it can be?
I need to replace leaky seals so I need to strip them down.
Hope you can help!
Cheers
Gert
Damper rod holder info
- Mr. Wibbens
You've seen this I suppose?
I believe the nut for the "E" series is a 29mm not a 27mm like the "H" uses
I have Fredette's tool, it has a 29mm on one end and a 27mm on the other
I tried making my own, but never found any place with that large a metric nut. I tried a large sae nut, it was close but slipped. Mine was really tight
- Mr. Wibbens
It did not work on mine, it was pretty froze upgrump99 wrote:If you cant find the parts you need, there is another way. Compress the fork and use an impact wrench on the external bolt. It has worked for me in the past.
Good luck.
I even took mine to a shop, I'd given up. Went back a few days later and he too had pretty much given up
Thats how I did my Vstrom forks. Just left them together, did not need to compress, spring pressure was enough
I just had to have a tool made for the allen bolt. Needed to be longer than I had. So I took an old allen key and had it welded to an old 3/8 drive socket
- Mr. Wibbens
Pretty sure it is 29gertie6car wrote:Thanks for the response Mr Wibbens!
which end fits the 29 or the 27 - the 29 mm end by the sounds of it? Is it just a matter of using a nut to push into a female hex hole so to speak or it the nut thread used/important?
cheers and thanks for your help, its much appreciated!
gert
The nut just sits in the female hex of the damper, to keep it from turning
I spose you could make something other than a nut. Like a piece of bar stock, 17mm x 29mm. Just need something to hold the hex in place while you loosen the allen bolt
one of the few tools I dont have is an impact wrench - cost a fortune in the uk!
spring pressure has always done it for me in the past but not on this set! not even when the forks are compressed!
sorry to be thick but would a 29 mm (it is 29 mmm right?) allen key in a socket work or is a hole up the centre required?
thanks in advance
Gert
thanks in advance
Gert
- Mr. Wibbens
29mm allen should word, no hole required. Dunno where you going to find one?
Should be able to take a flashlight and see what's needed down there
I can't understand why an impact wrench would cost any more over there
The compressor is the spendy part.
