I got compression of 150, spark and fuel is running. Where do I look next?
88 kdx 200
Its been sitting since december. I tried to start it a few weeks ago and came back and cleaned the carb yesterday(didnt clean the jets) and put in new plugs.
Getting old girl started
Is your plug wet?
Clean jets with guitar strings.... you DO play guitar....right!
no the plug looked good but It was the first thing I like to rule out. I like the Guitar strings idea a good alternative to compressed air.
I should check the tank, when i cleaned the carb the fluid was rusty brown colored. But no bits just color, wait its a plastic tank cant be metal. Just bad gas right?
I probaly shouldnt have mixed the drop of old gas with the new. But I thought a little wouldnt hurt. Any chance it did?
My point is... the plug should be wet... or else the jets are plugged.
- Mr. Wibbens
soak carb 30 minutes in Berryman's carb dip, be sure to remove all the plastic and rubber bits first
Well I dumped the old gas put in maybe a half gallon and she roared first kick. Since I didnt have enough gas i went and bought another gallon and half but I think i might of mixed it too rich. Cuz I cant adjust the idle it just doesnt make a difference wether the air screw is all the way in or out. It dies when I put the gas on. But will idle with the gas off. Could this be flooding, too rich mixture or possible carb problems.
Its starts first kick no matter what I switch the idle too.
- fuzzy
Clogged passage, or needle/seat problem. $$$ on pilot jet curcuit clogging. Wibs has good solution. That $20 can will do LOTS of stuff for ya. You ruled out Inda's 1st check, which is a good thing, otherwise you could be scuffing your cyl. Another is what I do, and just break carb down, blast passages w/ brake clean, and air hose out. Nothing beats the soak treatment followed by 120PSI though.
