I broke off one of 4 axle pinch studs on my kdx 220 (need to
I broke off one of 4 axle pinch studs on my kdx 220 (need to invest in a inch/lb torque wrench :banghead: ). It is the upper one closest to the hub.
2 Questions:
1. Are those studs that can be replaced? Or are the all one piece molded with the fork tube?
2. Is it safe to ride the bike with one of these missing? There is still one upper and two lower holding the axle pinch clamp there.
Thanks In Advance
2 Questions:
Thanks In Advance
- Rick
You are not alone! I broke one of the pinch bolts off as well. Yes, it can be fixed. Use some penetrating oil on the pinch bolt where it goes into the fork leg. Use a vise grip and unscrew the bolt. It comes out counterclockwise, just as you would expect. Do the same with one of the good bolts, so you can take it to a dealer (or hardware store) to try and match it. You will need the good one, since the broken one will not give you a correct size.
Kawasaki does not list a part number for the bolts, they would rather you buy an entire fork leg.
What I thought was a disaster turned out to be just a minor inconvenience.
We have a smart, experienced parts manager here, and he was able to find a barrel bolt that matched almost perfect - just a hair longer than stock. You could use a regular bolt, but they are not as strong as a barrel bolt. Of course, a regular bolt would be stronger than having nothing.
I can't get a photo uploaded on here, but pm me if you want a photo of the bolt.
The Right to Keep and Bear Arms Shall Not Be Infringed
http://i299.photobucket.com/albums/mm28 ... adBike.jpg
http://i299.photobucket.com/albums/mm28 ... /F-111.jpg
- Dewey
I have used a long set screw from a bolt supply store to replace these before. Don't forget the loctite!
The problem with using a standard bolt is, you may run it in to deep and damage the threads in the bottom of the hole. Then when you remove the bolt the threads come with it.
By using a set screw you can loctite it and feel when it bottoms in the threads, let the loctite cure and then install clamps and nut. Plus you can hold it with an allen wrench when you remove the nut so the set screw stays in place.
Of course OEM stud would be better if you can find it!
Dewey
02 -KDX220
02 -KDX220
My local Kawi dealer tried to charge me $10.50 for that bolt and I'd have to wait 4-7 business days for it to be "shipped" in from the California "warehouse."
Ace Hardware, instead. Or you can pick up one of those "Japanese Dirt Bike bolt kits." for $11 at a fraction of the per-bolt price from "the warehouse."
Rick
Rick
AZRick: You DO know you got bent over, right?
I have one'a those studs in my tub-o-stuff (not of much use on USD forks)..and it cost less than a buck...from the local dealer.
Didn't look, but...what is it? Something like 18in/lb? Not much!!
Do insure your put it together so that there is NO gap at the top.
The gap is at the BOTTOM! So...snug the TOP nuts first.
Yeah....87in/lb sounds good.
I should'a not said anything having not looked it up myself.
Thanks for posting the correct torque!
