First Dual Sport Ride
Kurt Franz
Post by Kurt Franz »
Well...finally have the KDX ready for a one day 300 mile dual sport ride. The ride will take place in Ohio and will consist of 40 percent 2 lane highways, 50 percent dirt roads, and 10 percent trails.
Eveyone is busting my chops telling me that I am a fool for attempting this and that the bike will fail on me because it is a 2 stroke, that mixing the oil and gas will be a pain, etc....
The way I see it, the only thing I really need to be aware of is not using the engine for braking when decelerating from any significant speed.
A temp guage would probably be a good idea.....anyone ever put one on their KDX?
Any other thoughts for me before I depart - please only serious things that need to be considered, not the fact that my keister will be sore, my hands will be buzzing, etc.....I already know this.... :grin:
My gut feeling is that the bike will fare OK but I will be hurtin afterwards....
KF
1987 BMW K75
1973 Yamaha CT3
2004 Kawasaki KDX200
1981 Yamaha PW50
How fast will you be going on the highway? Gearing? mods? Just curious.
Kurt Franz
Highway speeds 55 tops.
Stock gearing
1987 BMW K75
1973 Yamaha CT3
1981 Yamaha PW50
september9
Post by september9 »
Do you have a computer? If you get the right one you can get your temp gauge and also MPH, RPM, and/or a variety of other things.
1998 KDX 200
- 2000 KX 125 front end.
- Bills Pipe
- RB Head and Carb !!!
1987 Husqvarna 430XC
- Up-Tite Pipe
KarlP
Post by KarlP »
Sounds like fun!
300 miles, I get 20 mpg in the real tight trails, I'll guess 40 on the highway? Guess you'll need 4 fillups? Doesn't sound like a problem.
Kurt Franz
september9 wrote:Do you have a computer? If you get the right one you can get your temp gauge and also MPH, RPM, and/or a variety of other things.
Do you have a recommendation on the computer?
1987 BMW K75
1973 Yamaha CT3
1981 Yamaha PW50
TPMtec
Post by TPMtec »
I just completed an AMA Dual sport in PA on a 220. 100 miles a day. Mostly unkept state forest trails and fire roads. Stock gearing is fine. I use a etrex gps for mapping , speed, odometer instead of a computer. The odometer cable got beat a long time ago. With a 48 main and a 45 pilot I was getting 25 mpg by staying off the main. Which was about 45-55 mph.
When you fill up at the station, close your petcock. Add th oil after you add gas. Heavy oil will sink to the bottom. Shake it up real good and then open the fuel. I saw a motor get fried becasue of it.
It isn't the best bike for soing lots of road miles, but it works.
Teampromotion.com
01 GSXR600
86/01 xr200
01 kdx220
september9
Kind of depends on what you want in a computer/gps. I went with a Trailtech Vapor, but I got a friend with a Trailtech Endurance. Some people just run GPS's. There are other options available, but not sure off of the top of my head. I went with the Vapor for the temp gauge it has and I wanted a speedo for running roads. A GPS is cool, it can give you your speed, but also map where you are going. A computer won't do that, but some computers have different gauges like a temp and/or a tach in them. Some have count down timers for running checkpoints in races. If all you want is a speedo, you might be better served by a bicycle computer because they are cheaper.
1998 KDX 200
- Bills Pipe
- Up-Tite Pipe
Kurt Franz
how often between top end jobs if you are doing rides like this? I am a four stroke guy and still learning a bit about 2 strokes....
1987 BMW K75
1973 Yamaha CT3
1981 Yamaha PW50
TPMtec
Post by TPMtec »
I'm still new to this 2 stroke thing also. My kdx had it's top end done 2 years ago. I just had it pressure tested and it was still within factory specs. I rode 15-80 trail miles a weekend.
Teampromotion.com
01 GSXR600
86/01 xr200
01 kdx220
Jeb
Post by Jeb »
TPMtec wrote: . . . When you fill up at the station, close your petcock. Add th oil after you add gas. Heavy oil will sink to the bottom. Shake it up real good and then open the fuel. I saw a motor get fried becasue of it . . .
Out of curiosity - what happened in the case of the fried motor? Are you saying that someone added oil, then the gas, shook the mix, and still "fried" their motor?
CLICK FOR PICS!
Ogre
Post by Ogre »
I'll throw my lousy 2 cents in.
If your looking for a way to keep & measure your oil, I got a plastic liquor flask and marked it off in 1/2 gal increments of premix.
My longest one day run has only been about 130 miles, but I found the flask a very convenient way to keep and measure the oil out on the road.
I always add oil last as its the only way to know how much gas I put in and how much oil I need.
Never thought to close the petcock though as it has a reserve tube and think it is very unlikely that any substantial amount of the oil would actually go into the petcock/fuel lines, specially when adding oil last.
07 KTM 640 Adventure
Kurt Franz
I wonder if it is possible to install oil injection - as the KMX200 bikes have from the factory. If this were feasible I would do it in a heartbeat.
1987 BMW K75
1973 Yamaha CT3
1981 Yamaha PW50
radonc73
Post by radonc73 »
Oil injection is great but I would be worried that it would crap out on you, but it would allow you to carry more.
Master of the casual pace
83 KDX 200
93 KDX 250
84 YTM 225 DX 3-WHEELER
Kurt Franz
Did some of the earlier model KDX200s come from the factory with oil injection? I was reading some posts where it seems like this is the case. If so, would it be a tough job to implement it?
1987 BMW K75
1973 Yamaha CT3
1981 Yamaha PW50
radonc73
Post by radonc73 »
I have not seen it on a KDX, but I had and RT 180 as a beginer bike that had it. I had heard horror stories of it failing so I always pre-mixed it.
83 KDX 200
93 KDX 250
GS
Post by GS »
I've never heard of a oil-pump system failing...but of course anything *can* fail
I have! Happened to my DT125... gunk!
Only premix anymore....
Ogre
Post by Ogre »
GS wrote:I've never heard of a oil-pump system failing...but of course anything *can* fail
They must not have outboard motors where you live.
radonc73
Post by radonc73 »
That was my thought also. The oil would be more likely to gum up in the line especially if you didn't use all of it. I didn't have it working long before some guy told me they can fail.
83 KDX 200
93 KDX 250
