Gearbox Oil Poll
What gearbox oil do YOU use?
Spec'd motor oil
10
17%
Gear oil (Gearsaver..80W)
12
21%
Synthetic
9
16%
ATF (Type 'F' or otherwise)
11
19%
A motorcycle specific motor oil (Yamalube)
12
21%
Whatever is on sale at the World of Wally
4
7%
Total votes: 58
rdsrf
Gearbox Oil Poll
Post by rdsrf »
I found the discussion on gearbox oil in the "horrible squealing screching noise" thread rather interesting. Especially the article in the link CC put in there. What's everyone out there using and what are your experiences?
NM_KDX200
Post by NM_KDX200 »
I've been using Rotella T in my KX.
I used ATF and whatever 10-30 I had on hand in my KDX200.
Maybe I'll switch to something else... :grin:
1999 KDX 200
2001 KDX 220
2002 RM 134
2004 KX 125
So...where's the poll part? :hmm:
Vote HERE! ...until Inda puts 'em together maybe?
FWIW I use Yamalube 10/30-40. I used to use 'motor oil'. Valvoline. For motorcycles even. It met spec. My clutch squealed like a stuck pig. I haven't heard a peep out of it since the switch...and I 'use' it quite a bit more now than I did then.
Similar situation in my Honda (700SC). When the tune of the bike hit (around 9KRPM or so), the clutch would slip. New friction plates, new steels, new springs...same. With Yamalube (and another set of new everything)..no slip no more.
Note the input on oil on the link mentioned came from a Maxima geru. Another FWIW I s'pose, but it was based on a tad more than what some rider thought about it.
Gearbox oil poll
Fits with rd's question HERE!
Wow!! Right now....100% of the votes and voters say YAMALUBE!!!
yippee! :wink:
skipro3
Post by skipro3 »
I don't see my choice and there's no "other" for a choice either. I run Rotella in a straight 30 wt oil. Rotella is made by Shell I think and is for diesel motors. Diesel engine oil is formulated to hold particles in suspension more than standard oils do. Anyone who owns a diesel knows that within 100 miles, the oil looks like it's been run 100,000 miles it turns soooo BLACK!!! It really has to hold a lot of crap so I figure it works well in our bikes that don't have motor oil filters. I don't want gunk settling out into the bottom or any where else for that matter.
skythrasher
Post by skythrasher »
I voted on the motorcycle specific line, but I use motorcycle specific Golden Spectro 10-40. No squeals no slips.
2001kdx
Post by 2001kdx »
ATF type F.
rdsrf
Post by rdsrf »
I hadn't heard of ATF being used until recently. How does it perform for you? Good shift quality?
2001kdx
Post by 2001kdx »
Awesome. I never used to be able to kick my bike over in gear with one kick, it took two, but now with the ATF it's first kick. Really helps on dead engine starts. $3.30 a quart and I change it every 5 hours.
JoeR
Post by JoeR »
GM Sythetic Gearbox Lube. I had a couple of quarts of it in the garage left over from a trans repair. Shifts nice, clutch works good, isn't burned up when I drain it....so I'll probably stick with it.
Joe
'01 KDX200
blimpman
Post by blimpman »
I use a 2-part ATF & 1 part 30W Quality Motor Oil mixture. Change it every three rides. Trans shifts smooth as butter...
Brian
The destination is just a by-product of the journey
1990 KDX 200-E1 - Donated to my riding buddy Bill!
2003 YZ125
2008 WR250R
2005 TT-R230
**update* If 'your' choice isn't listed, it's 'cuz it wasn't worth the time to type it up.
:wink:
the editor
**end update**
btw...where did THIS idea ever get hatched?
'I use a 2-part ATF & 1 part 30W Quality Motor Oil mixture.'
2001kdx
Post by 2001kdx »
I've seen that alot from riders on ThumperTalk; maybe it's becuase they think ATF is too thin?
blimpman
Post by blimpman »
canyncarvr wrote:**update* If 'your' choice isn't listed, it's 'cuz it wasn't worth the time to type it up.
:wink:
the editor
**end update**
A guy named Ron.... :roll: :prayer:
Brian
2003 YZ125
2008 WR250R
2005 TT-R230
rick albert
Post by rick albert »
i use ATF - due to my A- clutch !!!!!
JUST RIDE !!!
Jeb
Post by Jeb »
blimpman wrote:>|<>QBB<
:wink:
the editor
**end update**
Yep, that's where I got it from, except quoting him it was "2 parts ATF..... 1 Part 10W/30 or 10W/40 GTX." And, yes, the GTX was in bold lime . . . for whatever reason!
Hatched righ'cheer on this website!
CLICK FOR PICS!
NM_KDX200
Post by NM_KDX200 »
skipro3 wrote: I run Rotella in a straight 30 wt oil.
Same here. I ran it in my YZ450F and it seemed to do well (changing every 5 hours anyway), so I just ran it in the bottom end of my 125.
1999 KDX 200
2001 KDX 220
2002 RM 134
2004 KX 125
Re: 'A guy named Ron....'
That is funny on SO many levels of humor...you have NO idea.
Anyway, thanks for the info.
2001kdx
Post by 2001kdx »
My name's Ron! :supz:
