Clutch lever with roller bearing? Anyone use one?
firffighter
Post by firffighter »
I mysteriously bent my clutch lever yesterday. Oh well, I didnt like that one anyway.
I wondered if having one with the roller bearing would make clutch pull super smooth. Not that my clutch is hard to pull, but I found the Fly model for less than $20 and thought I might give it a try.
Anyone use one before?
BTW, 100 miles this weekend in tight woods on Saturday, and desert on Sunday. RB mods performed great in both situations. Can lug better than before and now it has mid and top end. Awesome!
If none (friction) would be good then less is certainly better.
Whether it's better enough to matter is something else.
Considering that the other end of the assembly is a rotating flat piece of metal pushing on another piece of flat metal under considerable pressure, it's not exactly a friction free device.
I've not found hydraulic clutches to be much 'easier'..and there is practically no friction involved in one'a them. That doesn't make 'em 'easy'.
My clutch lever has been broken for years. I got tired of replacing them when they broke..so I gave up doing it. The 'lil stubby is still hanging in there!!
TWMOODY
Post by TWMOODY »
I never broke my controls however I didn't like the oe ones cause
they didn't fit with the bark busters I put on.
I bought ASV F1 clutch and brake levers about $50 each and the
clutch leverage can be adjusted and MUCH EASIER to use also
the look very nice.
Jeb
Re: Clutch lever with roller bearing? Anyone use one?
Post by Jeb »
firffighter wrote: . . . Can lug better than before and now it has mid and top end. Awesome!
Ron Black does a fantastic job for our 220s - more all around.
CLICK FOR PICS!
firffighter
Amen to that! What a fun bike!
I like my levers nice and close to the grips for easy access. The ASV's look a little far away.
TWMOODY
Post by TWMOODY »
Not sure they are much more than oe.
May just be the angle of the pic.
firffighter
Found out the Fly lever has to be used with a Fly perch and is around $50 for setup. I just went with Works Connection.
Levers and perches should always be a matched set....until some other mix-n-match is proven to your satisfaction.
rick albert
Post by rick albert »
GET AN EFM AUTOCLUTCH !!!!!!!!!!! AND SAY GOODBY TO YOUR CLUTCH LEVER FOREVER.............. :supz:
JUST RIDE !!!
firffighter
Did you end up getting one Rick?
rick albert
YES ! and i will never go back to a clutch ...............it surly is like chetting when it comes to doing dead starts at a hare scramble !!!!!! :lol: :supz:
JUST RIDE !!!
firffighter
You lucky dog :mrgreen: . Maybe next year.
hart125
Post by hart125 »
I got the moose bearing clutch with different cable attachment points for easier pull.. it is amazing,, I can do long enduros without my hand cramping up.. IMHO its about half way to an autoclutch which I like too
hart125 wrote:I got the moose bearing clutch with different cable attachment points for easier pull.. it is amazing,, I can do long enduros without my hand cramping up.. IMHO its about half way to an autoclutch which I like too
Where did you get it? Can't find that on google
thx
Will this do?
RockyMtn wrote:Allows you to choose 3 positions according to your clutch pull and riding style: Easy Pull, Medium Easy Pull, Light Easy Pull .
Cable adjuster is an anodized pivoting regulator, easy to adjust and reduces cable drag in all positions.
Vulcanized, exclusive silicon rubber grip for improved control in all weather conditions.
Needle bearing in lever.
Available as a standard size or shorty lever.
Motorcycle only.
From RockyMtn.
DO read the reviews. It's not real popular. As with most things MSR/Moose..they aren't too well made. That's my experience with their stuff anyway.
yep thx!
Good call on the review CC, don't think I will get it from them, sounds a bit shaddy workmanship
I've seen similar lever/perches that are considerably (4X) more expensive. I think the one noted is a knock-off of that piece.
Check this.
The review was written in '05..but posts are there to late last year.
I think ASV was the piece I was thinking of. Last I saw one (years back..and not from a 'cheap' place) it was pushing $200.
The price noted in the link above should be considerably more than one without a compression release.
...didn't look for a dealer or check availability now.
firffighter
For those prices, just add the hydraulic clutch. You could also put 1/2 down on a autoclutch.
The hydraulic clutch I had on my KTM's was very nice. But, the KDX is very smooth in stock form. I just added long levers and put the perch in toward the middle so the end of the lever in near the middle of my grip. Easy pull with one finger now.
An aside on brakes...but not all Magura juicers are mineral oil. Ski knows where to get DOT 3/4 setups.
lemmy
Post by lemmy »
Canycarvr, that ASV clutch lever you posted a link to isn't that same as the Moose lever is it? The Moose lever had three different positions to attach the cable and make the pull easier. I don't think ASV makes anything like this. I called them last year and they said they were planning on making something like that but so far they haven't. I wish they would because all of the Moose and MSR reduced effort levers are crap and break every time you touch them. The lever isn't so bad, it is the cheap perch that is made out of pot metal.
